03-11-2007, 09:58 PM | #1 |
Anyone running a sm465?
Surely some of you are! Speak up. What kind of these traits to these transmissions have? Are they streetable? I've never driven one before, so I was wondering if one would give alright performance and drivability behind a mild 350. The truck will be a 2wd.
03-11-2007, 10:01 PM | #2 |
Re: Anyone running a sm465?
its a perfect trans, very dependable and very tough
03-11-2007, 10:01 PM | #3 |
i have one in my gmc and it was behind a mild 350 which i would use if you where going to be doing some towing cause that bad boy has some torque to it i like it but thats just me
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
03-11-2007, 10:07 PM | #4 |
Location: vacaville ca, because it as far from indy as i can be
they are great for a 4x4 and work truck, they are the exact oppisite of what you should use in a street truck.
they where used in heavy one tons with 454s and heavy loads, it will handle whatever your 350 can throw at it. |
03-11-2007, 10:19 PM | #5 |
just put 1 in my 704x4 w/ 350. dont know much about them either but there in all the work horses,.
03-12-2007, 01:22 AM | #6 |
72 chevy
When i was 18 i had a corrnet440 dodge it had a 318 in it but i put a 340 in still to heavy of a car for a small block.. so it was a blast to take dads 72 c/20 and race it. Which i have it now it is a 350 4bbl with sm4565 2wd i would get on the line and put it in 3 gear and when the light changed i would just put it to the floor and side step the clutch. Well that truck would out run some fast 327 impalas LOL! only had to shift once throught the 1/4. I had so much fun that summer with it to this day my dad still well not buy cooper tires he says there junk. Well i thought thay lasted preaty good but i would never of told dad that LOL!! So there fun to race just not that good at it. The next year i got a dodge charger with a 400 mag and i camed it up and put a posi in it so the tires started lasting a little longer on dads truck . it was a really good farm truck though.
03-12-2007, 01:31 AM | #7 |
They drive down the road fine, there are still thousands out there hitting the pavement every day. They also have the exact same final ratio (1:1) as most other trannies, including the 3 speeds and the TH350, TH400, and PG (for whatever reason, people like to think that SM465's have a lower final ratio than most other trannies...no...they have a lower 1st gear. Speaking of, 1st is good for traffic jams, and moving heavy loads, and offroading. Start in 2nd all other times (unless you are CrashEd, lol). They are pretty much indestructible. What else do you need to know? They are not car trannies by any means. Large clunky shifts are the norm. You cannot get a short throw shifter, aside from cutting the stocker (and good luck with that).
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
03-12-2007, 01:42 PM | #8 | |
I love that story. I want to try that with my truck just once.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. Last edited by toms68cst; 03-12-2007 at 01:43 PM. |
03-12-2007, 05:07 PM | #9 |
I removed a TH350 and installed a SM465 in my 70 c/10 34 years ago because the TH350 was going south. In 1993 I converted to 4x4 with a different SM465 not because there was anything wrong with it, it just didn't have a transfer case on it. They're great heavy duty transmissions. If you treat them right, they will last for ever.
03-12-2007, 05:44 PM | #10 |
Cantankerous Geezer
Just don't try shifting one fast, it won't do it.
Fred There is no such thing as too much cam...just not enough engine. |
03-12-2007, 07:10 PM | #11 |
The SM465 is a tough tranny. They can handle a lot of torque and work well in short wheel base applications. The case is a top loaded/top shifting cast iron unit that is well ribbed for strength and measures 12" in length. The 6.55Granny gear is non-sychronized.
1st gear: 6.55:1 2nd gear: 3.55:1 3rd gear: 1.71:1 4th gear: 1:1 I've ran this transmission in many application including behind supercharged small blocks, strokers, and big blocks. The only failures I've experienced are a failed synchro in 3rd gear which let it pop out of gear, and the female 10 spline coupler stripping out. Both were due to old age. This trans will do best behind a motor creating a flat torque curve due to the big gear difference between 2nd and 3rd. Hope this helps! |
03-12-2007, 07:40 PM | #12 | |
With a 4X4, put the X-fer in low, the tranny in 1st, and you can get out and walk circles around your truck while it's busy going nowhere very fast...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
03-12-2007, 08:48 PM | #13 |
Thanks guys.
1969 GMC, what transmission is under that 5 speed shift knob? Kind of spawning my curiosity. I've never really researched GM manuals. The reason I ask if the tranny is worth using is because I found a complete 75 Chevy LWB for $250. I figured the whole front end would be usable for a disc swap, along with the power steering, power brakes, along with the sm 465 and ALL of the parts needed to switch it. |
03-12-2007, 09:00 PM | #14 |
I got acouple trucks with them...............We were on a 1/2 ton kick with 3 spd sag's..........Most with floor shifters. I got used of them and then bought a 1-ton with a 465..........The 465 was tight still as it wasn't used much, but I didn't like it at first, but the more I used it I could live with it.
I got one in my K-20 that has seen alot of use and it is pretty sloppy shifting, but after using it alot now, I can live with it. Personally I don't like the gear spacing, they are just spread to wide or in the case of 1 to 2, to close.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
03-12-2007, 09:51 PM | #15 |
That brings me to my next question--What parts are needed to tighten one up again, and are there any improvement kits available?
03-12-2007, 10:11 PM | #16 |
Got one in the 72 Blazer that I just picked up, but don't have it running yet. It is behind a 350 with a NP203, I believe.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
03-12-2007, 10:29 PM | #17 |
I have an SM465 in my truck, the shifter just seems sloppy, is that how they are, or is there a way I can tighten it up?
03-12-2007, 10:46 PM | #18 |
03-13-2007, 11:38 AM | #19 |
I agree with everything above but wanted to stress that if you want great acceleration,that 2-3 shift will usually let the ricers whiz past. I had a 465 behind a VERY torquey small block with 3.08 rear and 33x12.5x15 tires and I could outrun nearly anything in 2nd but that was it. First gear is actually good for getting a big load,,(ie.a trailer) started. I like my 435 much better than the 465 as it has better ratios and similar strength.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
03-13-2007, 08:15 PM | #20 |
WorkinLonghorn,
Tell me more about this 435. What did it come in? 4 speed? |
03-13-2007, 09:30 PM | #21 |
Used Register
Not a Cheby, but I run one in my Willys Wagon, wedged between a SBC283 and a twin stick D18 with a Warn OD. 16 forward gears and 4 sticks FTW!!
Trans is tough as rocks and almost as smooth. Herb |
03-13-2007, 09:38 PM | #22 |
im running one in my 72 stepside behind a 1973 455 buick with a centerforce dual friction clutch . gear ratios in the trans leave something to be desired .i run 3.07 's in the rear .i do beat it up and i know its a strong tranny and ive got a couple spares
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car Last edited by 66skylarkpost; 03-13-2007 at 09:39 PM. |
03-13-2007, 10:02 PM | #23 | |
03-15-2007, 07:59 AM | #24 |
there are two "435" transmissions. mine is the NP435GL with lower gearing (1st is into the 6.5 range -- i don't have my owner's manual with me)
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
03-15-2007, 09:51 AM | #25 |
Good point GMCBubba. Yours has a 6.68 granny low,3.34 2nd,1.66 3d.
It's about the same as the 465 with a slightly lower 1st and slightly taller 2nd and 3d. I didn't know those came in pick-ups,now I do,thx. >> The Close ratio version has 4.56,2.28,1.31,1.
