10-17-2002, 02:00 AM | #1 |
Convert 3/4 ton to 1/2 ton
As I have a 3/4 ton '71 GMC and want the looks of a 1/2 ton GMC, can I just change front spindles and coils plus the rear end? I want to lower the truck 4" and use 5 lug wheels all around. The darn truck is just too high.
10-17-2002, 02:36 AM | #2 |
Truck'n the alcan
Welcome aboard. Try using the search. I'm sure you'll find lots of info.
68 GMC 4x4 71 C20 Custom Deluxe 83 1/2 ton conversion van |
10-17-2002, 11:18 AM | #3 |
Fabricate till you "puke"
On the front end, you will need to use the 1/2 ton lower a arms, all 4 ball joints, & the outer tie rod ends, then the spindles will bolt on. Are you leaf or coil on the rear?
