Old 05-15-2008, 09:25 PM   #1
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Hey BBC gurus I have a Air Gap question??
I have a brand new EDL-1407 with the Air-Gap Performer RPM intake installed on my 454. I called summit today to get a throttle bracket / kickdown bracket. they told me that the Air-Gap didn't have direct support for mounting the bracket and that I'd have to use a universal one that mounts to the back left carb stud (which I have).
Problem is, when I mount it, it's too far forward for the kickdown cable to hook up without extending it all the way forward. Then, there's no travel left to go to WOT.
Thoughts / suggestions?
Thanks!
Kenny
87Lowrider is offline   Reply With Quote
Old 05-15-2008, 10:48 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Hey BBC gurus I have a Air Gap question??
Lokar
bigblock73 is offline   Reply With Quote
Old 05-16-2008, 12:28 AM   #3
87Lowrider
87Lowrider's Avatar
duh! - Thanks!
Old 05-16-2008, 01:28 AM   #4
Pyrotechnic
Pyrotechnic's Avatar
Jegs also makes an aluminum throttle/kickdown cable and return spring bracket that uses the front and rear carb studs on the left side. I really wish Edelbrock would get something together for this manifold.
Pyrotechnic is offline   Reply With Quote
Old 05-16-2008, 03:47 AM   #5
bigblock73
yeller
bigblock73's Avatar
Here is a pic of my 468/Air Gap and Lokar cables
Old 05-17-2008, 04:11 AM   #6
87Lowrider
87Lowrider's Avatar
I'll look it up and see if I can get a part number. I've got a call in to my local speed shop who is a Lokar dealer. I like the one Jeff has above.
Thanks!
Old 05-17-2008, 06:56 AM   #7
Pyrotechnic
How much did the Lokar bracket and throttle/kickdown cables cost all together ?
Old 05-27-2008, 07:03 PM   #8
87Lowrider
87Lowrider's Avatar
I have the same system as Jeff does above... It bolts right up.
Part Numbers:
Kickdown cable for the 700R4 - LOK-KD-2700HT $69.50
Bracket - LOK-SRK-4000 $26.00
24" Throttle Cable - LOK-TC-1000HT $45.05
Kenny
