08-06-2016, 02:26 PM | #1 |
What is this thing?
Maybe a horn relay? It is a Delco Remy and has 8H - 12v stamped on the bottom.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
08-06-2016, 02:28 PM | #2 |
Re: What is this thing?
Probably the horn relay. Also used (or very similar) on the HIGH blower circuit of the AC trucks, as well as for dual batteries, and speed warning.
08-06-2016, 02:40 PM | #3 |
Do you know where it would have been mounted? For some reason I don't remember taking it out. It may have fallen out when I was removing something else, I also don't remember removing any connector from it.
08-06-2016, 02:48 PM | #4 |
Do you have any options is might belong to? If it's the horn relay, it goes under the dash sort of up and left of the brake pedal mount. AC on over by passenger feet, aux bat out under the hood, speed warning by the cluster, etc...
08-06-2016, 03:20 PM | #5 | |
Thanks for the inspiration, I really didn't what to tear that factory wiring apart. Dale
08-07-2016, 09:44 PM | #6 |
Definitely not the high fan speed switch, it has one more prong
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
