i have a complete 2wd p/s set up on a 81-86 truck, box, pump, lines and 350 brackets and other parts available such as engine pullies, manifolds, smog AIR pump setup, etc
dont need much for any of this, i have no use for it is all... ------------------ A 68 C-10 panel and a 68 dually C-30 dump truck and a couple 71/72 chassis projects. http://messenger.msn.com http://communities.msn.com/196772ChevroletCSTsforever r68c30@hotmail.com |
![]() Join Date: Dec 2000
Fast,
I could use some of the engine accessory brackets, I.E. the P/S pump. Let me know. Thanks! Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 |
its all intact, so whatever you may need is there
Fast,
How about the whole accessory bracket set-up? I do not need the actual components, just the brackets and maybe the pump. Thanks! Doc
looking for the p/s related brackets only, right ? or ? just checking, I gotta know what all for sure.
thanks ------------------ A 68 C-10 panel and a 68 dually C-30 dump truck and a couple 71/72 chassis projects. http://messenger.msn.com http://communities.msn.com/196772ChevroletCSTsforever r68c30@hotmail.com |
