Old 08-09-2020, 08:02 PM   #1
bhemingson
Radiator sizes??
I am working an a Jimmy but I think this applies to four wheel drive trucks as well. My Jimmy came with a radiator but it sits slightly above the rad support and doesn't fit the bottom support channels very well. It has some funky spaces on the upper retainers to make up for that.
Looking at parts books online I believe a 1972 Jimmy w/o A/C and a 350 and automatic came with a two row rad with the transmission cooler. A/C trucks came with three and four r? Or do I have a radiator out a newer truck because it sure doesn't fit.
bhemingson is offline   Reply With Quote
Old 08-09-2020, 08:53 PM   #2
gmc684x4
Re: Radiator sizes??
Which rad do you have ?
2 core and 4 core have different rad support holders and rubber grommets
gmc684x4 is offline   Reply With Quote
Old 08-09-2020, 09:24 PM   #3
bhemingson
I think I have 2 core rad support holders and rubber bumpers and a 4 core radiator.
Old 08-09-2020, 09:33 PM   #4
truckster
truckster's Avatar
The 4 core takes a wider seat. It won't fit into the 2 core holder, so that might be why yours sits high.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 08-09-2020, 09:47 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Ill fitting aftermarket replacement maybe?
Old 08-09-2020, 09:47 PM   #6
Boog
laying low
Boog's Avatar
There have been numerous threads about this. I have a 4 row rad in mine and with the proper mounts and cushions it stood up too high still. I, and others, cut the back side of the upper and lower cushions to half thickness to lower the rad. Some made spacers to place under the top rad retainers. I thought mine due to being an aftermarket radiator for the ill fit.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-09-2020, 10:43 PM   #7
bhemingson
Thanks. Does anyone repop the lower brackets? I think using a 4 core is better but I hate it sitting up. Pulled my gas tank tonight and two holes. So that's next on the list.
Old 08-09-2020, 11:46 PM   #8
gmc684x4
Gmc pauls lmc or brother's should have them
Old 08-10-2020, 12:43 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
If your truck originally had the 2 or 3" core radiator and you are installing a 4" core with 4" core lower saddle brackets, the lip on the back of the core support will have to be bent down so that the bracket will sit down flat on the core support. If that wasn't done it will make the 4" saddle sit higher in the back.
LockDoc
Leon
Old 08-18-2020, 03:12 PM   #10
gmc684x4
Nappa should be able to help RADIATOR RETAINER SET 4-ROW # GMK4143326671S
