Fuel Gauge/Sender
When I went out and fired my '72 up yesterday, The fuel gauge went a stuck straight to the right (past full). Is this a bad sender?
Re: Fuel Gauge/Sender
Could just be the wire.
Make sure it's plugged in at the fuse box, and connected on the sender tab. Sometimes the wire can break or short out as it runs under the sill plate. |
I would bet that's it. I had the floor mat pulled up and was routing the wires better (so I thought).
Which color wire is it?
Should be brown.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Run a wire from the fuse panel fuel terminal to a good ground with the key on and the gauge should go back to empty. If it does then the sender wire is broken as you think.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
