Old 01-27-2013, 07:02 AM   #1
BBrendal
Recalculating.....
BBrendal's Avatar
Tach wiring question
Will an original tach work with a HEI distributor with no other wiring modificatons other then changing the connector and pluging into the tach connector on the distributor? Im just wondering because Ive seen "HEI Ign only" or "NON HEI" on some GM repop tachs.
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
Old 01-27-2013, 09:18 AM   #2
Andy4639
Old member
Andy4639's Avatar
Cool Re: Tach wiring question
Simple...Yes. The tach wire that went to the old coil just use it for the HEI tach terminal.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
