Old 11-05-2010, 05:42 PM   #1
Blake_H
Blake_H's Avatar
Assistance Needed
I have been searching the forum and have gotten close to answering some questions, but not close enough to be confident about doing what I'm planning on doing. So, here goes, and any help is very much appreciated.
I have a 1988 suburban that I bought for parts. Its in good shape, and I have already transplanted some easy parts off of it to my '87
In order of importance.
I would like to swap the cluster from the suburban to the truck. Will I need to repin the connector on the '87 in order for this to work?
Picture from the dash harness of the suburban:
I would like to swap the columns. The '87 doesn't have tilt, and the suburban does. However, the suburban was fully loaded and the '87 isn't. Will there be a bunch of wiring that I will have to repin? And if so, where can I find that info.
I would also like to swap the cruise from the suburban to the truck. Any pitfalls on this that I should be aware of? I have a pretty good idea on this one, but not having done this before, I thought I would ask.
Thanks for your help!
Blake_H is offline   Reply With Quote
Old 11-05-2010, 06:05 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Assistance Needed
Did the truck have idiot lights or gauges? Did the truck have delay wipers or just low/high/off? Did the truck have cruise to start with?
For the cluster, should be easy enough to just compare the plugs on each, as long as they are wired the same should be an easy switching of clusters.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 11-07-2010, 01:00 AM   #3
Blake_H
Blake_H's Avatar
Randy, thanks!
The '87 has gauges, no idiot lights. It also has non-delay wipers, and no cruise.
I'm guessing that this makes my goals a little more difficult to achieve?
Old 11-07-2010, 06:33 PM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Swapping the column over will be the easiest part. the control module for the delay wipers is mounted to the under side of the column and is a plug-n-play unit. And since you're swapping from a standard non tilt no frills column to one that has tilt with cruise and delayed wipers, you won't have to worry about changing out any of the controls as you already have them on the tilt column. As for the the cruise control make sure you get ALL COMPONENTS for it under the hood as well as under the dash. to include it's wiring/vacuum harness. You will need to punch a hole through the firewall right below you fuse block for the harness to go through (There is a dimple there where you'll need to drill. just measure the diamter of the groove on the grommet and use the proper size hole saw to drill open the dimple for the harness.
Under the dash you WILL NEED BOTH BRAKE SWITCHES As well as a large black module thats mounted to the right side of the brake pedal support bracket. THere may or maynot be a white module mounted to the back side of the lower dash right under the radio. If it's in the burb grab it as well. If it isn't there you shouldn't have to worry about it.
Dave
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
