Engine n00b
Tranny - 2 speed?
1970 c10 - I think the TH350... from 0-65, I only notice ONE shift, and at 75mph, its screaming pretty good (no tach)
Im tempted to just go to austin drivetrain and have them look/deal... Anyone have any simple fixes or is this an "open it up" thing? |
knuckle buster..
![]() Join Date: Oct 2007
Re: Tranny - 2 speed?
check them vacuum line from the intake to the transmission modulator, this happened to me before and all it was... was the vacuum came off! lol!
hope yours is that simple! ![]()
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
knuckle buster..
let me know if that worked, it may be something else.... too long to write out
its all about the +6 inches
try shifting it like a stick, first, then second, then try third.
Engine n00b
Will it run today?
I honestly find it hard to believe you would make it to 75 in second gear. It isn't very tall. I have a 350 and if I hit 50 it's screaming pretty good. 75 in third screams too. Are you sure you're not just missing the second shift?
Jaws, the 1971 Chevy Cheyenne Longbed. She's big, grey, and has an insatiable appetite! |
#7 | |
Engine n00b
checking my option sheet, standby. |
if there are only 2 forward selections on the shifter... it may be a powerglide 2 speed tranny. What does the SPID (option sheet) say in the glove box?
Engine n00b
powerglide, ill be damned.
Pics: ![]() ![]() |
Will it run today?
Also, if you only have D and L, that seems like it would be a two speed, maybe a Powerglide? The 350 would have D/L2/L1. With as much butchering as some of these trucks go through you could always have the wrong gear indicator. I just know in my 350 1st to 2nd happens very quickly and if you're just cruising sometimes I miss it.
most ppl think that in 70 the glide was no longer avalible... this is the 2nd one I've seen.
Engine n00b
#13 |
Engine n00b
And knowing what we now know - how can I make cruising at 65 not sound like im gonna blow a piston out the hood? Up my rear end ratio for final drive?
#14 |
rear drive ratio will need to be swapped for sane RPM's. That, or a 700 R4 or 200 4R.
Some ppl love the glide... mostly drag race guys. Personally, i'm not a big fan. I wouldn't call it a bad thing... just not good. |
#15 | |
Engine n00b
Since im a n00b and you are staying online apparently.... will the ratio need to go UP or down? (yes, im that much stupid on this stuff) |
#16 |
#17 |
Engine n00b
#18 |
#19 |
I am a Referee of life.
Down numerically.Supposing the current ratio is a 3:73 then going to a 3:08 will lower RPM's.It is a higher speed per RPM change.Knowing your current ratio will help determine what ratio you need to go to.Some one should post a calculator for RPM X tire size X gear ratio.You may be able to improve things somewhat by going to a taller tire though it wont be as much as with a gear swap unless the change in size is a dramatic one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 02-24-2008 at 03:39 AM. |
#20 | |
Restoring a 68 SWB
http://www.slowgt.com/Calc1.htm#RPMInGear |
#21 |
glides are fun for weekend cruisers...but no fun for highway driving,my 71 had a built glide and i loved it around town on friday and sat nights....
#22 |
Granny had a 350 with a powerglide in her 71 C10. I wonder if it was a transplant?
93 Sonoma 2.8/5spd 75 Malibu Classic 350/350 If it don't have round headlights and a carb, I don't trust it! |
#23 |
1972 Chevrolet SWB
power glides are mainly good for drag cars weighing 2500/2600 lbs or less.
The best mod I did to my gutless 283/powerglide 67 Impala with 336 rear gears was install a TH350........went from gutless non tire spinning to being able to get out of its own way and tire spinning made easy. Glides can be swapped for th350's with ease of parts swap and all. Its a very common swap that actually yields great results.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
#24 |
Long Fleet Club
This is what I use
For automatic transmissions you have to add around 300 RPM for the torque converter
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
#25 |
knuckle buster..
see, i told you it would be too much to write here
