Old 03-06-2014, 05:23 PM   #1
72supermike
SBC Parts
I have a small collection of parts I no longer need. Here is the list and the prices. They are somewhat negotiable, especially the more items you want. Take a look at the attached pics. I might be missing a few pics. Prices are before shipping. Thanks!
Edelbrock TM-1 SBC single plane intake good used condition. $65
Edelbrock 7501 RPM Air Gap SBC dual plane intake. Good used condition. sold
No name SBC Air Gap dual plane intake. Works just as good as an Edelbrock sold
SBC 400ci crank that has been machined for use in a 350 to make a 383 stroker. Barely used. Engine had an issue and was disassembled. Didn't affect the crank. Also have the balanced damper for it. sold
SBC Chrome Valve covers. Good condition. $35
SBC black with red lettering. Good condition. sold
Heat tabs for cyl heads. Tells you if you've overheated your heads. Adhesive them to the head and the center melts if the head exceeds 580*F. Have a bunch of them and will sell 10 for $5 Part # t-580 Pioneer brand
Mr Gasket 1" carb spacer. $10
Carter AFB Competition Series Carb 625 cfm electric choke with Vacuum secondaries. Been sitting so you might need to kit it. Good carb. Came off a running engine. sold
York A/C compressor. With bracket for SBC $75
SBC 400ci flexplate. Very good ring gear. have 2 of them. $50 each
SBC 350ci flywheel. Good condition. Ring gear looks really good. standard practice would be to resurface it at a machine shop. Cost is minimal. $85
SBC starters. 1 mounts through nose, 1 mounts through the bottom/side. Both work fine. sold
SBC short water pump. New, never installed. Has small crack were the heater hose pipe screws in. Doesn't affect the pump. $25
Various SBC crank and water pump/fan pulleys. Good condition. All for sold
3 alternators. Internally and externally regulated. 1 has a sbc bracket. All for 3 $40
SBC clutch fan. sold
Fan spacers that mount the the water pump. 2 for $10
SBC engine mounts. Qty:5 All for $35
http://s820.photobucket.com/user/mik...s%20for%20sale
72supermike is offline   Reply With Quote
