Bench seat question
67 c10 bench seat. The drivers side locks in position. The passenger side always slides.
I was looking in an LMC catalog and I see a cable that appears to link the 2 sides. Is this how I keep the passenger side from sliding? thanx |
#2 | |
The Older Generation
Re: Bench seat question
The first thing I would do is to lube all of the seat adjuster parts and slides under the seat. The cable (or rod) (or wire) that connects the two seat adjuster latches only releases the latches. There are individual springs on each side that cause the latches to re-seat in the notches in the slide. Here are a couple of pictures of the seat adjuster parts and a couple of threads that show how everything goes together. http://67-72chevytrucks.com/vboard/s...d.php?t=659974 http://67-72chevytrucks.com/vboard/s...d.php?t=420114 http://67-72chevytrucks.com/vboard/s...d.php?t=418802 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-09-2017 at 12:00 PM. |
The cable locks and unlocks the adjuster on both sides at once. If you don't have the cable your only gonna open one side. If the pass side is sliding all the time there is a little pawl[hook looking thing] that goes into the slots on the side of the track. The whole thing may need a real good cleaning and oiling maybe then you will be in good shape. It sounds like it may be gummed up so that it is not locking properly. Jim
thanx both. This is a big help. Gonna clean it good, and hopefully I just need the cable. and a spring for the passenger side.
dave |
#5 | |
![]() Join Date: Aug 2018
This info helped me this evening as I fixed my bench seat, specifically the passenger side that was missing much of the hardware. Your info helped me piece it all together. Many thanks.
#6 | |
Good deal! Glad people are still getting use out of the older info posted on here. I will try and post a close up picture of how the parts fit together in this thread tomorrow. LockDoc.
![]() Join Date: Feb 2009
I can only give specific orientation where a rod is used. My 72 has a cable (wire). Personally I like the rod better, because they don't break.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Search function is so nice & helpful... good for finding what parts were scavenged off my bench sliders!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#9 | |
Glad you found this. Looks like I failed to post a close up picture of the parts together. I know I posted one somewhere, I will try to find it. Edit: I couldn't find anything better on my computer than what is in the third link posted above. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-03-2020 at 12:35 AM. |
