Mirror in need of viagra...
My Suburban has a little bit of a personal problem...its mirror can't stay up. Are these fixable or do I just need to buy a new one? I'm not sure what the internaks look like so i figured I'd ask before i tried fixing it and making more gray hairs on my head.
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
Re: Mirror in need of viagra...
I think its a lost cause but you might squirt some super glue in it and have someone get it aimed properly as a temporary measure. Maybe someone else has had better luck than me and will share their ideas. Mine were like that and I finally bought new ones .Good luck.
Be careful with the Viagra. If your mirror doesn't drop after four hours, you'll need to consult a doctor.
#4 | |
Active Member
![]() Join Date: Jul 2007
Does it have adjusting screws in the back? If it does try tightening them if you haven't already and see if that will do it. Otherwise, I agree that you'll probably need to replace it.
Nope, it has 4 rivet looking heads...
Red Green it, Duct Tape.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Be careful mine did that and then the mirror head flew of going Down the highway. It hit the side of my truck, good thing I don't have good paint. Looks like your paint is nice so be careful .
Posted via Mobile Device |
