Old 01-22-2004, 12:29 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
1/2 and 3/4 ton front
In fourwheelers project superburb, they mentioned running 1/2 ton calipers on their 3/4 ton front dana44 so they could use 15" wheels. Something about the 1/2 ton calipers are slightly smaller and no grinding is necessary. Anybody tried this? Any thoughts or opinions?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-22-2004, 01:18 PM   #2
CHEVYJEFF
CHEVYJEFF's Avatar
you will still have to grind some because the caliper mount is bigger due to the bigger diameter of the 3/4 ton rotor. But the calipers are supposed to be the same
http://members.cardomain.com/chevyjeff
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
97 REGAL LSR 2100 (BOAT)
CHEVYJEFF is offline   Reply With Quote
Old 01-22-2004, 01:28 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I had heard that the 3/4 ton calipers had a larger piston. I ask because I also understand that the 3/4 dana caliper are not as beefy as the dana 60s which respond very well to grinding(as seen on CK5).
Old 01-22-2004, 10:09 PM   #4
Beast388
Suburbans RULE!
Beast388's Avatar
Jim.....I have my original 1/2 ton calipers on my 3/4 axle. I still had to grind to fit 15" rims. It isn't the calipers that cause the need to grind, it is the larger diameter of the 3/4 rotors.
I also compared the original 3/4 ton caliper pistons to the my 1/2 tons, and they were the same.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 01-23-2004, 10:33 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Ben, you remember the superburb article, were they just smoking crack? I started this because I have a set of 15x10 8-lug rims and I'm buying a 71 GMC 3/4 4x4 and would like to use them. You know keep it simple between the two trucks.
Old 01-23-2004, 07:33 PM   #6
drink2mny
drink2mny's Avatar
Yeah the 1/2 and 3/4 d44's calipers are the same size. The D60's are different.
As for using a 1/2 backing plate, I just can't see doing that.The 3/4 ton rotor is bigger than the 1/2. If you could do that I would think everybody would easily convert to 3/4 ton..
As for fitting the 15" rims on 3/4 ton GRIND baby GRIND. I believe with the right offset you don't have to with steel rims, but if they are aluminum you will end up grinding..
I run 15x8 on a d60 front and 14bolt with disc brakes on the back.
had to grind alot on the front and very little on the back..
Support The Board
drink2mny is offline   Reply With Quote
Old 01-24-2004, 08:40 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks you all. I had the parts house pull the rotors so I could visualize, the 3/4 ton rotor is way bigger than the box the 1/2 ton rotor comes in. Grinding might be the option. I have two sets of 15x10 8 lug rims: the US wheel white wagon wheels on my K25 and American Racing white wagon wheels that were on my K25 when I had the BFGs. We'll see which works the best.
Old 01-24-2004, 11:42 PM   #8
Beast388
Suburbans RULE!
Beast388's Avatar
Jim.....here is a pic of my grinding. Not only did I grind on the calipers, but I hammered the backing plate down as well. It was easiest to test fit with just the rim...not tire mounted. It took me about 2 hours per side. My rims have a backspacing of 4.25".
--Ben
71 GMC Suburban 4X4
The "Beast"
