Still livin the "dream" in '54
Fuel tank relocation questions...
Hello all! I have decided to take the tank out of the cab on my '54 and I was wondering if anyone had some ideas on the best "factory" tank set up I could go with. I thought maybe a later model Chevy tank would work that used the manual fuel pump would work good. I figured someone else has done this and I was hoping to learn from them. Thoughts?
Thanks in advance for your answers! D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
Re: Fuel tank relocation questions...
The best matchup I have seen is a 47-48 tank under the bed. I did see a tank from a 76 chevy truck under the bed of one once but I have to say he had to modify most of the tank for it to fit around the axle. Like I said the one out of the 47-48 fits best and it's also used in the panel trucks. Also look a few of the car tanks from the 60s. They work well. You can actualy get all the modern stuff in the late 80s tanks but it's up to you. Mounting latter tank requires a lot of knowledge in fabrication but you can get some cool results.
Posted via Mobile Device |
The 69 or 70 Mustang tanks fit real nice and they are VERY reasonable, change the sender and you are finished
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
yep ^
x3
