Parking Brake Installation Help
My painter did quite a bit of disassemly when I was not around and now that I have the cab back, I am trying to put it all back together. I am trying to reinstall the parking brake assembly. My question is this, I know the two threads go through the firewall, but does the parking brake bracket mount behind or in front of the dash?
Meaning....does the bolt go through the dash and then the brake assembly or through the assembly and then the dash? Either way it is going to be a tight sqeeze... Thanks in advance |
![]() Join Date: May 2005
Re: Parking Brake Installation Help
it goes through the dash into the pedal assembly. It is a tight squeeze, but you can kind of push it in at an angle.
Pete |
