Old 07-20-2009, 10:37 PM   #1
ol Curt
Junior Member
ol Curt's Avatar
Cab Soundproofing?
Ok, I'm not to that point, but I have been thinking about this tar paper like matting I have been scraping off my floor prior to replacing rusty areas. Did most, or any of you use a soundproofing material and if so what brands? I will be replacing my original black mat with a new rubber one to match the original, but wouldn't mind keeping some noise and heat out.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 07-21-2009, 03:02 PM   #2
ol Curt
Junior Member
ol Curt's Avatar
Re: Cab Soundproofing?
Anybody ever use any of this?
http://www.lowes.com/lowes/lkn?actio...372-278-383769
Old 07-21-2009, 04:23 PM   #3
rendus
rendus's Avatar
Originally Posted by ol Curt View Post
I used that in my Galaxie. 3 rolls did the entire floorboard and under the back seat. I probably should go back and do the doors and what not. Good stuff though, really thick and sticky. Has a bit of an odor initially, but it goes away pretty quick. I really can't say if it helps with noise reduction, my 460 is mighty loud . But I have no doubt it keeps the heat from coming up through the floorboard from the transmission and engine.
It's definitely something I'm planning on doing with my 66, along with a liberal coating of por-15 on the floor panels.
rendus is offline   Reply With Quote
Old 07-21-2009, 07:41 PM   #4
ol Curt
Junior Member
ol Curt's Avatar
And none of you other yahoos have used any kind of sound\heat proofing material?
Old 07-21-2009, 08:13 PM   #5
terd ferguson
terd ferguson's Avatar
I used the double sided foil type stuff at lowes. It has bubble wrap in the middle. I glued it down with 3M spray adhesive and taped the seams with that silver insulation tape. This was in my '53 Bel Air, by the way. It worked great and was cheap and looks good too (even though it'll get covered by carpet). It's easy to cut with regular scissors for the little spots the full size won't cover. And no tar to get all over you and your clothes, lol.
I'll do the same thing in my '63 pickup when it comes time (soon).
***EDITED TO ADD A PIC***
You can kind of see it here...
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 07-22-2009, 10:13 PM   #6
austex66
austex66's Avatar
I went with Raammat from Raamaudio. This stuff sticks REALLY well, and is not asphalt based like the others. They were great to deal with.
66' Chevy SWB:350ci-th350,frt. disc brakes, pwr steering, 5-lug
waltshow.com/Chevy
austex66 is offline   Reply With Quote
Old 07-25-2009, 01:07 AM   #7
bird7263
Urban Chop Shop
bird7263's Avatar
Check out my build thread. On page 4 you find step by step how I did mine. I used the stuff from Lowes.. WOW!!! Cheap easy and the cab is so quiet now I can have a conversation on my cell or with my wife with out much engine noise. I have exhaust that dumps out underneath just before the axle.. Its super loud from the outside but very very quite on the inside. I used fiberglass to fill some small rust spots on the floor.. worked great.
2003 Chevy Trailblazer LTZ, 2.5" Susp Lift, Tinted, HID's/LED interior/ Lot of upgrades and little mods
1965 Chevy 1/2T Longbox, soon to be a slammed shop truck
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=591266
Semper Fi Marines
bird7263 is offline   Reply With Quote
Old 07-25-2009, 07:14 AM   #8
ol Curt
Junior Member
ol Curt's Avatar
Ryan,
The link for the peal and seal did not work. But, they show this stuff....does it look lie it this what you used? I am going to use armaflex over the top of it before my new rubber mat. The armaflex comes in sheets and is the material used to insulate pipes(dark foam)
http://www.lowes.com/lowes/lkn?actio...433&lpage=none
Old 07-25-2009, 02:34 PM   #9
Hilandr451
Hilandr451's Avatar
I was given a cab by my neighbor and she had installed about $400.00 worth of Dynamat. I wouldn't have gone that way, but I don't think I would have used a tar/ mastic based product either. I think there must be a more affordable rubber based product available. I'm looking for something to go inside the doors.
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
Old 07-25-2009, 02:59 PM   #10
bird7263
Urban Chop Shop
bird7263's Avatar
Ryan,
I am not sure why that link does not work anymore.. Bummer. But here is a link to the company that makes it. http://www.cofair.com/peel_seal.aspx
I say that is worth calling them and seeing if they can mail you some. I only paid $15 a roll for the 6"x25'. Two rolls did my floor. I have used dynamat and fatmat in the past on some rods I built before someone from this web site turned me on to the peel and seal. The peel and seal works great, easy to install and is way cheap.. Let me know.
Semper Fi Marines
Old 07-25-2009, 06:00 PM   #11
ol Curt
Junior Member
ol Curt's Avatar
Well, there is this.. http://www.cofair.com/butyl.aspx ..no foil on top though.My original cab had a material under the rubber mat that was similar to tar products.
I have also read of folks using a paint with ceramic chips in it for insulation. I found a recipe of how to make it much cheaper but need more research on using it. I think the ready to use product is here...
http://www.metalshield.com/
I would use the foam or jute on top of this to help with sound.
Old 07-25-2009, 06:16 PM   #12
rendus
rendus's Avatar
Here's another ceramic coating...
http://www.lizardskin.com/
Old 07-25-2009, 09:25 PM   #13
ol Curt
Junior Member
ol Curt's Avatar
Yes,
Actually that's the one the guy was duplicating. He used some ceramic stuff that is used on RC airplane repairs ($8.95 gallon) and mixed it with paint. I think I have the links for it at work. I'll put them up Monday.
Old 07-25-2009, 09:31 PM   #14
ol Curt
Junior Member
ol Curt's Avatar
This one might be an inexpensive alternative!! I thin k this guy sell to a lot of the guys over at the HAMB.
http://www.lobucrod.com/
Old 07-25-2009, 09:38 PM   #15
Woogeroo
an older truck, but a custom sound proofing deal:
http://www.alanhorvath.com/54chevy/doors_quiet.php
He has lots of interesting projects on there that he has documented relating to his truck.
-W
Woogeroo is offline   Reply With Quote
Old 07-26-2009, 06:56 AM   #16
ol Curt
Junior Member
ol Curt's Avatar
Thanks Woog.... I also found this.
http://www.crankshaftcoalition.com/w...mic_insulation
Old 07-26-2009, 07:35 AM   #17
jason65
Registerd User
jason65's Avatar
Hey Bob. Lilred66 has been useing the stuff from Lows on his rigs. He seems to like it.
jason65 is offline   Reply With Quote
Old 07-26-2009, 09:24 AM   #18
ol Curt
Junior Member
ol Curt's Avatar
Thanks Jason,
I'm going to meet Tony in two weeks when I go to pick up a TH350, automatic column, etc. from him. Maybe he'll have some tips about how or where to buy it from Lowe's. Their website shows it not available at our stores locally. When I try to order online it states "not available in our area".
Old 07-26-2009, 07:43 PM   #19
ol Curt
Junior Member
ol Curt's Avatar
I was at Lowes today and saw yet another brand. It only came in 4" x33' rolls, but I suppose it could be used. They also had the butyl material in rolls. It does not have foil on it.
