Old 02-20-2008, 12:12 AM   #1
pyro883
Stumble
I just recently timed my truck, and it seems to be running good thru most of the RPM range except at idle it has a stumble?
pyro883 is offline   Reply With Quote
Old 02-20-2008, 12:47 AM   #2
HomerJ
HomerJ's Avatar
Re: Stumble
Pyro,
Check to see if your carb's accelerator pump is shooting a stream of fuel.
HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73
67 Chevelle SS Clone 454/TH400/3.73
HomerJ is offline   Reply With Quote
Old 02-20-2008, 06:41 AM   #3
pyro883
Re: Stumble
and now it back fired thru the carb?
Old 02-20-2008, 08:21 AM   #4
DavesRide
DavesRide's Avatar
Re: Stumble
Don't check it's while running. Was it stumbling before checking or changing timing? I have a junk 2 barrel carb on mine until the weather breaks and it does the same. Runs great until I try to get it off idle. Backfire is either off time or possibly not good enough accelerator pump shot of gas. Other things can cause this but you gotta eliminate the normal places.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 02-20-2008, 08:22 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Re: Stumble
Backfiring thought the carb may be caused by fuel/exhaust leaking out the intake valve. May be a sticking valve, worn out valve or valve seat or even bad cam.
Could still be a timing issue but if it runs smooth most of the time it may be a bad valve. These are usually more noticeable during idle. As the speed increases the missing is reduced somewhat.
Do a compression test on all the cylinders to see if there's one that's off by a bunch compared to the others. If all checks out, then you may have a vacuum leak and/or excessive fuel going into the intake area...
68gmsee is offline   Reply With Quote
Old 02-20-2008, 09:36 AM   #6
Billla
Billla's Avatar
Re: Stumble
Timing first, always.
The question is - what's changed if this is a new problem?
Billla is offline   Reply With Quote
Old 02-20-2008, 10:04 AM   #7
69long"n"low
69long"n"low's Avatar
Re: Stumble
dont forget to try a leakdown test on the cylinders
69long"n"low is offline   Reply With Quote
Old 02-20-2008, 05:01 PM   #8
pyro883
Re: Stumble
It was running worse before I fixed the timing, It was backfiring even up around 2500 to 3000 rpms before adjusting the timing..
Old 02-20-2008, 07:50 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
Re: Stumble
what's it show on a vacuum gauge? you ARE using one right?
68C15 is offline   Reply With Quote
