02-18-2011, 04:54 PM | #1 |
Thinking of a change to power steering
thinking hard about doing it and have a couple questions.
#1 have heard about varable ratio's, anybody done it and the out come? #2 don't want to go with used unit, figure they would be just as sloppy as what i've got now. #3 can i use my pittman arm off the standard steering? Thanks for any input. |
02-18-2011, 04:59 PM | #2 |
Re: Thinking of a change to power steering
What year truck - keep your old unit (it's worth $ as a trade in on a rebuilt). Not sure what you mean on variable ratio. After '77 or '78, not sure, the stop to stop number of turns on the steering wheel was reduced, and those will work in our trucks.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
02-18-2011, 05:20 PM | #3 |
op's sorry its a 68 with manual steering.
02-18-2011, 05:59 PM | #4 |
Fairly easy switch over - lots of threads on this. do a search on power steering conversion or look in the FAQ's.
02-18-2011, 08:18 PM | #5 |
Vintage 4x4s
Ram assist if you want something cool and aren't adverse to a more complex installation or proper rebuild with upgraded gaskets to avoid leakage. If you want an easier cheaper install don't use ram assist.
jud
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-18-2011, 10:47 PM | #6 | |
yes you do need to change the pitman arm, here is a part #, sorry a bit blurry, the other # is K6143 and a pic of it on with the new gearbox also a pic of the old gearbox and arm. Hope this helps.
68 Long stepper My other ride ,,, 07 Streetglide.. |
02-19-2011, 10:05 AM | #7 |
Thanks Glider; who's sector? and is it varible?
