Max AD Rearend Width
Would a 65in wms to wms rearend with 15x8 wheels with a stock offset be too wide for a 52 gmc? I know from reading that around a 60in may require tubs or spacers. So, I was thinking the extra 2.5in per side may be ok.
I am not able to just put it under there right now and see for myself, so I am trying to pick the collective brain of this forum lol. If it is too wide, does anyone know of a narrower 5on5 rearend that may work? Thanks in advance for any information.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
AD Addict
Re: Max AD Rearend Width
Most 5 on 5s were truck so they were pretty wide. The station wagons were 5 on 5s, too but I think at least 63".
65" would be ok with stock wheels/tires, but not with wider ones, especially if you are lowered. 71-87 truck 5 lug rears are 63-1/2" over the drums, so you might want to look at one of those. Also, most GM full size cars except Chevy were 5 on 5" through the 70s and 71-76 full size Chevys were 5 on 5" too. Lastly, some 90s Impalas/Caprices were 5 on 5" and should be ok for width, except the wagons.
http://67-72chevytrucks.com/vboard/s...d.php?t=417493 Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
AD Addict
The 50s Olds was 5 on 5 and lots of drag racers like that one for strength. Not sure of the year but there is an option to research.
Why are you going 5 on 5? Most 5 lug conversions for the front are 5 on 4 3/4" or are you using a later truck front end? Another one with width issues... Last edited by Dan Bowles; 11-11-2010 at 10:17 AM. |
The box width is 50", the fenders have about 11" of usable clearance on each side. You will want to keep the side wall of the tire at least 1" away from the bed sides and at least 1" from the inside lip of the fenders.
Without knowing your rim backspacing and what size tire you will be using we can only guess. Using these dimensions you can figure out whether it will fit or not. 65" is wider than I would put under an AD truck. The 2nd gen F-body axles are 60" and work well with rims with a 3.75" back spacing. 4" BS can also be used if the tire size is not too wide. |
A 3/8, 1/4 or 1/2" spacer between the wheel and brake durm is much easier to manage to get the right clearence between the bed side and fender, so maybe a narrower axle is better, I like a 255 tire which fills up the fender opening and clears the fender and bed.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#7 | |
Ray
I've been wondering/looking into a rear axle for my 49 and saw this after doing some searching on here I see the ZR2 might be an option for me. If I get a stock 4X4 axle for $250 and have to buy spacers I might as well by a ZR2 for $300 and not have to use the spacers. My thought is to use off the shelf 16x10 rallye style rims with a 5 inch back space. I don't want to have to spend extra buck for a custom back space. worst case I have to find some used 15x8 with a 4 inch back space. Any thoughts, suggestion donations?
A 10" wheel with 5" BS means that you will have about 6" of wheel sticking out past the WMS, and the tire is going to stick out beyond that. What is the width of the ZR2 axle?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 11-13-2010 at 05:54 AM. |
Raycow from my research on here a stock 4x4 is 60" and a ZR2 is 63"
10" is a dream 8" will probably be a reality Last edited by RootBeer 6117; 11-13-2010 at 06:47 AM. |
This is a qoute from Blue Jeep
<<ZR2 rear axle is pretty close to 63" wide. I used a regular 4wd rear axle in mine (60"), with stock 2wd s10 wheels (less backspacing than 4wd wheels) and I still need 1" spacers for the tires to clear the inner fenders. I think the ZR2 axle would be perfect for someone who doesn't want to tub the bed.>> __________________ not sure of the tires and wheel size |
Sounds good. Thank you.
Ray
#13 | |
![]() Here's the 60" wide "regular" 4wd s10 axle before I did the spacers: ![]() I run the plain-jane s10 wheels: ![]()
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#14 |
You and fifty two,(sounds like a song) made up my mind for me I'm go huntin for ZR2.
One more web site I use a lot is www.car-part.com I can search the state of mizzery or the US for parts and see who has the best price. Last edited by RootBeer 6117; 11-14-2010 at 09:51 AM. |
