57 cab removal help
I am almost ready to pull the cab off my 57 gmc but have a few questions. How does the column disconnect from the steering box? I also want to pull the motor and trans...are there just 2 bolts on the mounts on the sides of the trans or am I missing any...thanks for any help you can give me....
Re: 57 cab removal help
+2 on how to disconnect the column...
please, anybody... do tell and thanks!
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
![]() Join Date: Jul 2010
If the steering column on a GMC is anything like a chevy of same era, the column and the gearbox are integral and must come out together.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
So I can't use that column with a camaro subframe then?? How about a column from a mid 70's chevy van??
Steering column comes out by removing the steering wheel, bracket under the dash, cover at the floor, column shift handle (if 3 on tree), pull the pitman arm, unbolt the steering box from the frame and pull it out of the frame, pull the box and column out thru the firewall from the firewall side.
You can use the stock column by cutting it loose from the box and adding a bearing at the bottom (available online from vendors). The bottom of the shaft needs modified too I think. There have been a couple of threads on here with pictures, a search should find them.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 11-12-2010 at 01:16 AM. |
Right on!! Thanks OrrieG
#7 | |
![]() Join Date: Feb 2010
Thanks! |
No, I have not used it but it should show up with a google search or someone here will chime in.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#9 | |
http://www.classicparts.com/1947-59-Steering-Coloum-Conversion-Lower-Bearing/productinfo/76-987/[/URL] |
I got mine from Tucker's. They called it a Column Saver kit when I bought it.
