Progress pics of my burb
Here's a few pics of how my engine compartment has changed in the last 2 months. Old - stock 350 with a SM465. New - 6.0L vortec with a 4L80E. It is so much nicer to drive now. Hopefully within the next month or so I'll get the front end swapped over so I can have 4 wheel drive again. Still needs a little cosmetic work under the hood but that will come in time. It's my daily driver so I can't do too much at once.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. Last edited by boostat4500; 01-10-2007 at 11:23 PM. |
Re: Progress pics of my burb
And here's a few of the interior. There is no longer an original wire or fuse or fuse holder left anywhere on the truck. I've only had the truck about 3 months so it's progressing pretty good. Mechanically it's almost ( just needs the front axle swap ) done. By spring I hope to have the body done so I can get it painted, and then I'll finish the interior.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. Last edited by boostat4500; 01-10-2007 at 11:32 PM. |
![]() Join Date: Apr 2005
Welcome from PCola, FL. Nice conversioin. Who's harness did you use? What about the fuel tank and pump? I'm getting ready to do a 5.3/4L60E in my 69 Suburban. Check link below.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Too Dumb To Know Better
You're making good progress for it being a daily driver.
turbo enthusiast
very nice
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
It's the stock GM harness with the un-needed plugs, like smog equip, removed. Does have a OBDII port added in so I can monitor everything. It was modified by Jeff at PCMAmerica.com. I got my computer from him also, awesome prices! As far as fuel, I just installed an in-tank pump and return line into the stock tank. I'm hopeing to build a custom tank soon cause I hate going to the gas station. Probably do something around 60-80 gallons.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
BlahBlahBlah
Here is a thread by Faster57. He installed a newer larger tank in his burb. Maybe it can give you some ideas.....
http://67-72chevytrucks.com/vboard/s...d.php?t=215597 |
Where did you get gauges? Nice touch!
The gauges are TPI Tech. Thanks for the link on the tank! Does anyone know of a factory tank that's even bigger? I'd love to only have to go to the gas station about once a month if possable.
40 gallon is the largest single tank stock system.
there was a place making a 43 gallon 1st gen bolt in tank but it's pricey. with a lifted 4x4 you can slide the tank forward above the axel by doing this you could possibly squeeze in 2 of the 31's (or 25's for heigth) '73 and up blazer tanks.
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's 1995 K2500 Burb as daily driver 350 with 193K miles 1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse |
