11-05-2010, 07:06 PM | #1 |
mystery problem
I have a 99 GMC Sierra. Today I had to go get it off the side of the road because it had died on my wife. I got it started & it was knocking and smoking & would not idle. It would die any time I let off the gas & the breaks would not want to work. I got about a block down the road & the battery acted like it was dead & didn't even have enough juice to roll up the windows I checked the battery & it was holding charge. I took the alternator out & took it to autozone & they say it passed. I have no idea what's wrong so I was hoping someone here would know.
"First off I'm an OKIE.... so don't call me Tex!" 1985 Chevy C-10 SWB 305 looking for posi rearend 2003 GMC Sonoma (DD) 1999 GMC Sierra 4x4 327 (Out Of Commission) 1999 Pontiac Grand Prix GTP Supercharged 2004 Chevy Malibu (Wife's Hot Rod) |
11-05-2010, 07:16 PM | #2 |
Re: mystery problem
are they power brakes? Did the vacumn line to the brake booster come loose or split? Sounds like a massive vacumn leak to me.
11-05-2010, 08:01 PM | #3 |
Re: mystery problem
but how would a vacuum line cause it to not run & drain my battery to where it won't start
11-05-2010, 08:04 PM | #4 |
Re: mystery problem
Vacumn line will definately make it not run. I suspect the battery issue is a byproduct and will go away with the vacumn line fix. Ck the vacumn line fromr the brake booster to the rrear of your manifold.
11-06-2010, 11:03 AM | #5 |
Re: mystery problem
I checked the vac line and it looked good. Any other suggestions on what the problem could be?
11-06-2010, 12:57 PM | #6 |
Re: mystery problem
Fuel pressure regulator possibly. Little diaphragm on the fuel rail, drivers side. Has a little vacuum line running to it, yank it off and see if the line is wet on the inside with gas. (It shouldnt be)
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
11-06-2010, 04:49 PM | #7 |
Re: mystery problem
I would also suggest checking your grounds to the engine as well as the battery cables
11-07-2010, 04:12 PM | #8 |
Re: mystery problem
I think the battery is coincedence. They crap out this time of year... I vote for a broken valve spring. I fix a bunch of these for that. Do a compression check to verify. if you have a intake spring break you will have no vacuum for brakes and will barley run. if you dont have a gauge remove valve covers and inspect for broken spring. It takes like 10 mins a side and usually the rubber gasket it reusable. I may be way off base with this. Its fresh in my mind from fixing one yesterday,.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
11-08-2010, 12:22 AM | #9 |
Re: mystery problem
I'm just going to have to get it to my shop & yank the engine, I planned on doing a complete overhaul anyway. This will just give me an excuse lol.
