05-03-2023, 11:49 AM | #1 |
'70 K5 front axle swap w/'80's Dana 44
Does anyone know what year Dana 44 front axles I can direct swap / bolt onto my '70 K5 Blazer, with no significant modifications to the assembly? I'm making the swap so I can have disc brakes on the front. I found some axles from '80's era square body K5 and K10 trucks that the seller says will work. I realize I may have to swap out the knuckles. Thanks in advance for any replies.
05-03-2023, 01:52 PM | #2 |
Re: '70 K5 front axle swap w/'80's Dana 44
anything up to about '88 but it will likely be a corporate 10 bolt...most all after about '78 were 10 bolt...
the D44 is arguably slightly stronger, but if you're not going to bash on it, the 10 bolt is fine...all have disc brakes everything from the knuckles out will interchange with the D44...the inner axle shafts will not fit...they are slightly larger on the D44 I just did this swap on my '70 K5 using a 10 bolt from an '87 Suburban. I added the sway bay as well...most of the 80s models will have one.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 05-03-2023 at 01:58 PM. |
05-03-2023, 05:21 PM | #3 | |
05-06-2023, 04:46 AM | #4 |
A working axle from a 72 with disk. Sold to the good guy a while back with my rear axle. Direct bolt in. https://67-72chevytrucks.com/vboard/...d.php?t=844297
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
