09-09-2008, 02:23 PM | #1 |
4X4 from 2WD any suggestions?
I just recently found this site and love reading all the posts so decided I might ask a question myself. I have a 77 SBSS GMC and a 79 3/4 ton Chevy I will be putting them together to make one good vehicle. Neither of these are 4X4s and I am considering making the short box into one. I have a 454 with a blower possibly putting out between 500 -550 HP. Does anyone have any recommendations for transfer case, transmission, and axles? How difficult will it be to switch it over? And what about newer systems or even AWD?
09-09-2008, 03:48 PM | #2 | |
Re: 4X4 from 2WD any suggestions?
09-09-2008, 06:27 PM | #3 |
www.73-87chevytrucks.com
Easiest: Find a donor 4x2 frame and switch the bodypanels.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-09-2008, 08:03 PM | #4 |
Weekend Warrior
Behind a Blown BBC:
Trans: TH400 TCase: NP205 Front Axle: Dana 60 Rear Axle: Corporate 14Bolt (Full Float Axles) www.pirate4x4.com is a good resource as well
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
09-09-2008, 09:01 PM | #5 |
Happy to be here
If it were me and I wanted a serious off road capable truck, I would build the 79 3/4 ton. Primarily because it's a LWB, and I think they trucks better and perform better off road.
Of course that depends on the terrain in your area. Down here where we have mostly flat terrain, and 4 wheeling usually means mud, a LWB has the advantage.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 09-09-2008 at 09:01 PM. |
09-10-2008, 12:21 AM | #6 |
It'd be alot cooler if you did
wasn't there a pretty detailed post on here a few years ago about doing this swap? Seems like the guy made his blazer 2wd.
*edit* here it is... http://67-72chevytrucks.com/vboard/s...d.php?t=168231 Last edited by smashingchuck; 09-10-2008 at 12:39 AM. |
09-10-2008, 04:46 PM | #7 |
Thanks for all the posts. I am planning to make this more of a show truck than an off road truck. I have considered swaping bodies with a newer truck. Thought I would get some input from all you more experienced truckers first. I always have the option of leaving it a 4X2 and putting on some fatties on the back. Thanx again.
09-11-2008, 04:23 PM | #8 |
