12-20-2007, 12:33 PM | #1 |
Old member
Speedo Cable
OK,
I need a longer cable and housing. I need about 6" more to make it right. The old one is in to much of a bind and it jumps when going slower than 20 MPH. Would like to find one longer. New if possible. Junk truck or car.
12-20-2007, 12:43 PM | #2 |
Re: Speedo Cable
They had several lengths at Advanced Auto/AutoZone (forgot which one I bought at) when I replaced the one on my 70. I just bought the longest one and it was about 6" or so more that the original cable.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-20-2007 at 12:44 PM. |
12-20-2007, 04:29 PM | #3 |
Old member
Re: Speedo Cable
Did it come with the outer sleeve that screw's on to the transmission and back side of speedo.
12-20-2007, 04:51 PM | #4 |
Re: Speedo Cable
bring your old cable(inner and outer) in to the autoparts store with you so you get the right replacement// i have better luck and i think better quality at NAPA and carquest
12-20-2007, 05:00 PM | #5 |
Old member
Re: Speedo Cable
Thanks,
I will have to try the local NAPA this weekend.
12-20-2007, 05:40 PM | #6 |
Re: Speedo Cable
Yes they came with the correct ends. Mine was AutoZone part# (CA-3004)
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-20-2007 at 05:42 PM. |
12-20-2007, 06:26 PM | #7 |
Re: Speedo Cable
just pull out the inner cable, grease it up with white grease as you re-install it and it wont bounce anymore. its DRY......
I BELIEVE IN JOHN 3:16 |
12-20-2007, 06:30 PM | #8 |
Re: Speedo Cable
Any speed shop can make you a custom cable.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
12-20-2007, 08:14 PM | #9 |
Re: Speedo Cable
you should not need a custom cable if truck is not modified.
12-20-2007, 08:32 PM | #10 |
Re: Speedo Cable
speedo attachment on the 700r4 is a little farther back. I had the same problem....just get 4x4 speedo cable...it's a number of inches longer.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
12-21-2007, 01:48 AM | #11 |
Old member
Re: Speedo Cable
Thanks guy's, that's the problem SactoJim,
700-R4 has it streched to the limit and it bounces at the lower end. 20 MPH or less. 4x4 cable Kool! BCOWANWHEELS, Done that it helps but it still bounces.
