Old 10-09-2004, 02:38 PM   #1
ronh72c10
Header questions
I've got a set of hooker comps that were supposed to be from a 72 Cheyenne. I planned on using them in the burb but when I did put them in this morning there seemed to be very little clearance between the header and the lower right control arm grease fitting.
Anybody have any suggestions for headers for a 3/4ton burb, that they know fit?
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 10-09-2004, 07:16 PM   #2
crazy longhorn
Fabricate till you "puke"
I think you will have that issue, with many headers. i run a set of Hooker comps on my longhorn(#2452 painted). my sb is mounted in I 6 position, giving 3 1/2" of setback....& no issues with the lower arms! Depending on how close you are, you might opt for a 90 degree fitting on the grease fitting.....if you have 1/4 " clearance, it will never hit, as the grease fitting doesnt move up/down(just rotates, as the a arm moves up/down). one other thought , is the eng mounts could be "beaned out" (sagging). best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-10-2004, 12:52 AM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
When I had a small block in my 72 C/20 I had a set of Flowtech headers and had no clearance problems...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 10-10-2004, 07:58 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I had Hooker comps on my orange 69 and had to use a 90 degree grease zerk on the lower rear bushings.
Close, but never any problems.
Old 10-10-2004, 08:23 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
ditto to that tx just said.
Old 10-15-2004, 10:36 PM   #6
ronh72c10
Just an update, I picked up a set of flowtech ceramic coated headers and put them on tonight. I was surprised how good they look and there's plenty of frame clearance, I may have to move a few brake lines but apart from the passenger motor tower being a little close everything looks great.
Ron
72 GMC 3/4ton 4x4
Old 10-15-2004, 10:53 PM   #7
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I had to bend some brake lines with my flotechs. I'm glad I inspected real good after the install. They were in contact with the line. That couldn't be good. I've since wrapped em (no ceramic) and heat on the brake lines should no longer be an issue.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 10-15-2004, 10:58 PM   #8
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
chickenwing, So you mean that you mummified your headers? Just jokin'. It's getting close to Halloween, you know.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 10-15-2004, 11:09 PM   #9
Longhorn Man
chickenwing, onless that is a compitition only vehicle, you'll want to remove the header wrap. That stuff will cut the life of the headers to just a year or two on a daily driver.
Old 10-15-2004, 11:17 PM   #10
chickenwing
Believe it or not, I'm ok with that. They were $100. Hopefully when they rot out I'll have the $300 for the ceramic shorties I really want.
Old 10-15-2004, 11:17 PM   #11
Longhorn Man
Cool...as long as you know.
Old 10-15-2004, 11:19 PM   #12
chickenwing
Yeah, That was the only good information that parts kid gave me. You here about my harmonic balancer problem on a previous post last month?
Old 10-15-2004, 11:20 PM   #13
Longhorn Man
dude, if it's more than 10 min ago...it's kinda fuzzy to me.
(I don't remember)
Old 10-16-2004, 02:56 AM   #14
Jerrys1stgJimmy
Where'd you get those blue dress up items, that looks slick!
Jerrys1stgJimmy is offline   Reply With Quote
Old 10-16-2004, 11:03 PM   #15
ronh72c10
Thanks, those are actually chrome pans, covers, etc that I powder coated with a translucent blue, I'm really happy with them, they turned out pretty well.
Ron
72 GMC 3/4ton 4x4
Old 10-16-2004, 11:35 PM   #16
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Looking Good Ron. Have you started her up yet? Bet she sounds pretty sweet. Keep up the great progress!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada!
- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs
- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 10-17-2004, 01:52 PM   #17
ronh72c10
No haven't started her yet, got to get the shop ready for the winter and put the wood stove in it, so that's probably all thats going get done this weekend. Also will probably be building a leanto on the back of the shop next weekend, so not much more happening for a while.
Ron
72 GMC 3/4ton 4x4
