04-25-2016, 01:34 PM | #1 |
new wheels help needed
long time no post, looking at getting new wheels. I am definitely going staggered, I want to have 15x8 up front and 15x10 out back. I want to go with US mags U101 indy slots. The problem I have is the 15x10s have a 3.75 inch backspace and -50 offset. And according to the research i have done, 3.75 inch backspace wont work unless i modify my inner rear wheel tubs. Which I do not want to do. Any advice would be appreciated! Thanks!
http://us-mags.com/indy-u101-truck-w-5493.htm
1979 GMC Sierra Classic Freshly lowered 5 inches |
04-25-2016, 02:32 PM | #2 |
67-72 parts collector,…
Re: new wheels help needed
I think you are confused.
A 10" wide wheel with a 3.75" bs will be close to the BEDSIDE not the inner wheel tub. A 15x8 rally wheel has a 4" bs and there is tons of room between the wheel and the wheel tub.
04-25-2016, 02:44 PM | #3 |
Ahhhh yes that is a good point! makes more sense now, looks like i wont be able to run a 15x10 in that wheel after all.
04-25-2016, 02:50 PM | #4 |
Did you measure your truck to confirm that?
04-25-2016, 07:53 PM | #5 |
Check this on how to fit your wheels.
http://www.hotrod.com/how-to/wheels-...heels-fitment/ |
04-26-2016, 02:29 AM | #6 |
Cruzzzn' Vet
15x8 for the front 4" BS
15x10 on the rear 5" BS This will tuck and prevent rubbing |
04-26-2016, 03:19 PM | #7 |
is your truck an example? if so could you show pics please!
04-26-2016, 03:40 PM | #8 |
Cruzzzn' Vet
I have a couple here
http://67-72chevytrucks.com/vboard/s...d.php?t=621042 |
04-30-2018, 08:05 PM | #9 |
Does anyone know of 20x10 with 4.5 backspace and -25 offset will fit on stock rearend
