01-02-2003, 03:18 AM | #1 |
L.E.D. Freak
Pics of airtanks/valve mounting. Custom aluminum tanks?
Can some of you air bag guys post some pictures of where you have your tanks/valves/compressors mounted? Also I'm planning on getting some custom tanks made 4 total at 45.00 each is that cheap? They will be 4"X30" long. Is there a company that makes aluminum tanks around 4" diameter around 2 1/2'
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
01-02-2003, 04:28 PM | #2 |
Flamin' Bass
Here's the whole thing, temp mounted on plywood while I'm re working the bed. I'm going to get the next larger size (80 or 120 cuft) supply tank when I mount it in the bed because the tank I got now emptyed too fast. Guess I was playing too much!
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
01-03-2003, 02:23 AM | #3 |
L.E.D. Freak
That will take up alot of room. That's why I want to use 4 4" tanks so I can put them width wise under the bed floor of my blazer. I'm going to start piecing together my bag set-up starting with tanks and two valves and just rear bags. So I can tow a U-haul. 20's will be first.
I wish some one here had bags on a 2wd blazer so I could se there set-up.
