Champagne Taste on Beer Budget
Well shortly after taking possession of my '72 Chevy C/10 I found out the top of the raditor was coming apart!
How in the world it didn't start leaking all over the place is beyond me! Check out the pictures. I bought the raditor off ebay for about $125 plus shipping. Suppose to be a direct replacement but found out the top raditor mounts are round and the new aluminum one is square. It fits but it's just a tight fit, and yes it's only a 2 row raditor. But should be fine for now.
Coming Soon: Project 1970 Country Truck |
Chemist under the hood...
Re: Aluminum Raditor install
Do you know what size the inlet and outlet pipes are? Also, that's the coolest rad cap. Where did you get that?
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
Nice rad, please give us the link or the seller's name. I think i've been looking at the same ones for my truck. You may have purchased the radiator designed to fit in the four row mounts and not the 2/3 row mounts like you have. I believe he sells two types, one for the 2/3 row and one for the 4 row. I bet if you buy the 4 row mount kit with the brackets and cusions, you will get a much better fit. Also, are the tubes inside the radiator one inch wide or smaller?
Is that a regular two core or racing two core? The racing two cores use 1" cores vs .5" cores in a regular radiator. From what I have found and read in the past, the two cores with 1" cores seem to cool better.
Just to clarify, the tubes that run inside the core can be varying widths. A one inch wide tube is best as it will have more surface area to help cool the water better. This is why aluminum rads are better. A two row core (two rows of tubes) alum rad with one inch wide tubes will usually cool better than a 3 or 4 row brass-copper radiator with the much smaller width tubes. Going with a smaller width tube in an alum rad defeats much of the cooling advantages of an aluminum radiator since the copper/brass material actually is better at heat transfer. However, if you don't have any cooling problems, just want to save weight and have a cool looking radiator, then the difference between one inch tubes and smaller tubes may not be so important to you.
#6 | |
![]() Join Date: Jan 2008
Has more rust than truck...
I think this is the one he got.
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories I sent them an email asking if they make a 3 core with the smaller tanks. I think I may have just found my radiator ![]() |
They replied saying the 3 core is not availible with the small tanks. Here is a link to the 2 core with the smaller tanks.
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories |
Yeah, these are the ones I was looking at, too. For an alum rad, 3 row is not necessary if the 2 rows are one inch wide each. Heck, you might not be able to get 3 rows of one inch tubes to fit the tanks. However, if the tubes are less than one inch, then maybe a 3 row makes sense. I need the wider tanks since I have a factory 4 row right now. Looks like an awesome deal, especially when OReilleys wants $179 for a brass-copper 4 row. I can have this alum rad for less and save some weight. I just need to know how wide the tubes are on these. If less than one inch, then not really worth it to me to get right now.
![]() Join Date: Apr 2000
any more info on the radiator and the cool cap?? i`m needing one for my 402...
thanks
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
looks to be a Mr. Gasket thermo rad cap. http://www.summitracing.com/parts/MRG-2470S/?rtype=10
#12 | ||
![]() Quote:
And I think like someone said the only problem I had is the mounts. A friend of mine said I could cut off one half of that curved mount and should work just fine.
#13 | |
![]() Quote:
I am pretty sure its just a plain jane 2 core raditor. But for the money I think it works just fine!
#14 |
Beware of Radiators4Less. I just e-mailed them and they said that their 2 row rads have one 1 inch tube and one 1/2 inch tube. Not the best set up. If you are going to an alum rad, you should get one with at least two 1 inch wide tubes so as to maximize the advantages of going to aluminum.
#15 | ||
"I ain't nobody, dork."
I have dang near the exact same aluminum radiator in my 1972 GMC 1500. You will need the 4 row HD radiator upper and lower mounts. The tank is as wide as a 4 row HD... even though the radiator is only a 2 row.
I had to covert mine to 4 row HD mounts. The radiator I have cools just fine. I was stuck in traffic for 2 hours in 90 degree heat on the interstate last summer. No probs... Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#16 | |
![]() Quote:
Or should I just modify what I have to make it fit? Thanks!
#17 | ||
Any of the 67-72 truck parts catalogs have them. I got mine from Wes at Classic Heartbeat (he's local for me). There are vendors here that prolly sell them too. You'll need the upper and lower retainers and the rubber pads that go in them.
If you try to modify the ones you have...you run the risk of the steel rubbing on the aluminum, and possibly wearing a hole through. Gary
#18 | |
Chevy Lover Till The End.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
