SWB 4X4 CLUB
dash bezel question
I was wondering if this dash bezel is rare. The reason I ask is that I have not seen any other that has the choke and throttle like it anywhere. I have not seen this reproduced anywhere either.
Jason Sorry for the odd picture. Last edited by jay_shy; 10-25-2005 at 10:48 PM. Reason: forgot pic |
Re: dash bezel question
i don't see a point for the throttle knob, maybe that's why it's rare. my right foot can work the throttle.
Designated A-hole!
Hand throttle for work trucks, let the clutch out in granny gear and set the throttle, get out and load your hay, greens, whatever. Or so I've been told, that's the first one I've seen.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#4 | |
Just my thoughts on what it might be. Mike |
And Don't Call Me Shirley
![]() Join Date: Oct 2005
Years ago I managed a couple towing companies and some of the old retired towtrucks were still out in the back forty. They had the old Holmes 440 "spaghetti boom" wrecker bodies on them. They had hand throttles like that for speeding up the winch during wreck recoveries and so on. Also, when picking up a car or truck that was heavy, you wanted to speed up the motor in the towtruck so it wouldn't die when putting a load on it. Of course they had a hand throttle in the rear on the wrecker body as well, which was used most of the time. I would imagine anytime a truck was equipped with a PTO to run some sort of accessory or equipment, a hand throttle might be handy. Am I rambling?
Rick Tucker 1969 C20/Custom Camper (the Green Machine)Sold 1970 GMC 4000 COE (future Ramp Truck) 1972 K10 Longbed (restoration begins June 2020) |
BTW, I bet it's mighty rare nowadays.
Post Whore
![]() Join Date: Feb 2000
My 69 has the manual throttle on it, however, it is located under the headlight switch on its dash bezel.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
cool, and rare!
when in N it would kick the Alt. in for big accessories.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
My green 67 has the throttle also just missing the knob.
They are not to common but there are a few out there
'68 C-20 396 CST CC
![]() Join Date: Mar 2005
Throttle Cable = Fast Idle (warmup)
Mine was setup (from the factory) to be the fast idle circuit on my Big-block truck. It has an original Holley 2-barrell with a manual choke that needs a fast idle at warm-up. I can pull the throttle knob all the way out, but only the last 1/4 inch affects the idle.
Some of these must have been setup for PTO's and the other uses mentioned in all the posts above, but I bet you'll never see one without a manual choke also. Come to think of it, I've never seen another original BB 2-barrell truck!
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES ![]() 01 Jetta Turbo Daily Driver ![]() 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico ![]() |
My dad's 53 has a throttle and choke cable. The throttle served two purposes.
1: You worked the hand throttle while you started it with the foot starter. 2: As mentioned above, pull it out while in granny gear to work. My buddy found out it works really well for cruise control in his 51 GMC. He drove to South Carolina a while back in it and used it. It's funny how we're so used to modern stuff that when we get in something old and simple, it's complicated. ![]()
greatest cruse control ever and nobody knows !
#13 |
I just pulled the bezel from my 72 and it had all for holes, no thottle switch. I'd say for a PTO or to keep idle up. It is kinda wierd to see 4 switches on a dash, IMO but different non-the-less.
#14 |
I would think that using it for a cruise control COULD be dangerous due to the fact that it doesn't cancel out when you need to hit the brakes.
I thought they were in all (or maybe most) 2 ton and larger trucks for PTO use. At least every HD truck i have seen had it.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#15 |
I have a manual throttle on my 1/2 ton 72 cheyenne. I always wondered if that was rare and from reading this it is. The Throttle is on the right side of the bezel underneath the washer-wiper. The Lights are on the left side. So there are only three of these holes, since it does not have the choke.
#16 |
SWB 4X4 CLUB
my bezel has four knobs like solvers except I don't have the tach. Yet.
Jason |
#17 | |
![]() Join Date: Nov 2005
Re: Throttle Cable = Fast Idle (warmup)
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
#18 |
its all about the +6 inches
Camper trucks used them too... IIRC, longhronjeff's 69 CST/Camper Special 3/4 ton big block longhorn has that too. I know when he got it there were still heater hoses going into the bed that were just tied in together, the was for running heat in the camper in back. Kick the engine on, rev to 1500 - 1800 RPM, solid charge on battery, steady 200 degree coolant circulating into the camper...and a tired motor after only 60,000 miles.
