![]() Join Date: Aug 2014
LQ4 accessories drive w/ a no limit frame
I picked up an lq4 from an 06 chevy van and a 4l80e. I plan to run the pro10 no limit frame, and I'm working on getting the engine cleaned up and ready before I buy the frame (also to allow me more time to save for the frame).
I have an ls6 manifold I plan to run and I'm also going to run a single turbocharger and a/c. I know that the truck accessories won't work with the ls6 manifold, plus the accessories on the motor I picked up were shot. So I need to make sure I have space on the passenger side of the engine bay for the turbo, but most of the a/c set ups I see are high mount. Will this work? (I plan to run a vintage air setup) And the other concern is to have clearance around the aftermarket frame and inner fenders. Will an fbody setup work? I don't want to drop a few thousand on a march setup or billet specialties deal. I'd rather use all oem brackets or something like what kwikperf makes if possible.
1970 C10 Short wide -No Limit Pro-Tech Chassis 6.0 LQ4 / BW S480 Turbo 2004 Pontiac GTO, 419rwhp/378rwtq, -H/C/I/E, M6 2014 Cadillac CTS-V Auto |
Re: LQ4 accessories drive w/ a no limit frame
I used fbody on my LQ4......this should give you an idea how they fit. I plan on using the stock AC bracket and notching the frame slightly if needed.
