1966 c20
Hello,I am new to this forum,but not to chevy trucks,they make up most of 30+ years of driving,always one behind the shed,or in the yard,the other morning when I got up and looked out I seen another took up residence,so while doing a little research on it I found this site,I plan leaving this truck much as it is,with some upgrades in suspension maybe others,I have not had but one other this style that was in the middle eighties,the first thing I will look at,will be which motor I will run,small v-8,or 250 6cyl,it has a 4-speed truck trans,I not sure of trans and rear end gearing yet,what is the average gas mileage for these trucks with these set-ups,stock engine,has anyone swapped the stock trans for a newer 5-speed out of a car or truck,thanks that is enough for now I will check back later,
![]() Join Date: Sep 2011
Re: 1966 c20
It just showed up...Yeah, Right
![]() A lot of engine and tranny swappin going on around here. There is a good thread on doing a T5 tranny swap on the 1st page I belive.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Re: 1966 c20
Thanks, Mike for your reply,I followed the links to your pics,looks like you have it really bad case of it,nice stuff,I look around.
Re: 1966 c20
If yours has the 4.57 eaton rear end you'll get 9-11 mpg no matter what engine is in it.... My 327 V8 gets 9mpg no matter what. pulling a ton of landscape material home from home depot or completely empty that 4.57 is what kills it.
I have plans for a 3.73 GM 14 bolt swap and a built 700r4
Active Duty Air Force 02'-Current ![]() Proud dad of 3 girls, 1 boy and 1 TBD in Dec of 2012 - Lucky Husband "Family owned and operated since 1969" Dad's 66' Custom Camper - Big Family Small Budget |
Re: 1966 c20
ozzyman,thanks for the reply,I think probably 6 cyl,original motor,would make sense for a stiff gear in a 3/4 ton,I will try to check things out soon,it was a trailer ride home,thanks
