09-20-2024, 05:31 PM | #1 |
Blue 67
Engine Oil Extractors
Hi:
Does anybody use them? If yes, what brand and if you are happy with it.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
09-23-2024, 06:13 PM | #2 |
Re: Engine Oil Extractors
The only one I've ever used was a pump up model with a tube that does the sucking. You pump it to pressure, stick the tube in and turn the valve. It worked great for sucking the oil out of a differential through the fill hole. -Kevin Random photo but that unit is Northern Tool for 20 bucks.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
09-24-2024, 08:22 AM | #3 |
A friend of mine used one, and swore by them. He had a stanced Falcon. It was beyond ignorantly low. So getting the car up was a good bit of work, and the extractor made it fast and easy. I think he even covered the drain when he armored the pan.
Me I have no issue crawling under my truck, but if it was lowered like the previously mentioned Falcon. I would seriously consider one. DAP which is a VW enthusiast on youtube tested one on a GTI, and it got all the oil out. The results heavily depend on the shape of the pan, and location of the dip stick in relation to the deepest part of the pan. Bonus points for extractors. Is they are good to recover tranny fluid before you drop the pan, and rear diffs to. |
09-25-2024, 11:03 AM | #4 |
I use the Topsider for my boat. I've even started using it for the mower as it doesn't make a mess; mower/tractor drain plugs always seem to be placed where they will make the most mess!
I did have to use some JB Weld putty around the neck of the pump to tank cap to get a good seal, but it works really, really well. Best of all, it is QUIET. A drill pump is much louder. Good luck!
Semper Paratus |
