Old 10-08-2006, 07:30 PM   #1
arkracing
Weekend Warrior
Another 4x4 Question - '71K-10
I noticed yesterday that my drivers side Front spring seems to be a little weak and that the rear shackel is bent. Not enough to stop me from driving it though.
I would eventually like to convert this truck over to a K-20 (3/4 Ton - 8Lug - with the bigger brakes.
Since the availability of '73 + trucks is better than '71-'72 K-20's I figured that one would be a good doner for the axles.
Are the spring perches the same on the '73+ axles as the '72 - axles or would they have to be cut off and relocated?
What about the springs - are they the same length? - Where is a good place to get '67-'72 3/4ton Front Springs (LMC has them for about $160/ea - to the 3-leaf ones, my truck has 2-leaf ones and LMC wants $300/ea for those) Besides we all know that LMC sells a bunch of crap.
Anybody ever do this???
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 10-08-2006, 08:35 PM   #2
qksilver
Re: Another 4x4 Question - '71K-10
Check with some of the lift companies. I have a set of soft ride ones that i got used for 100 bucks. The front axles are the same perch width and will bolt up. the rear axles 73- are different and if I remember correctly the springs are longer also. A one ton rear is suposed to be the same width as the 72-older and a bolt in
qksilver is offline   Reply With Quote
Old 10-09-2006, 06:11 AM   #3
vtblazer
vtblazer's Avatar
I have a complete 1972 factory 3/4 ton drive train if your interested.
For the suspension, I've got alot of stuff from Off Road Design and they've always done me right.
http://www.offroaddesign.com/catalog...rossmember.htm
Here's another good link for more stuff.
http://www.automotive-links.com/par/off/off.htm
I remember seeing a post about your new 'acquisition'
vtblazer is offline   Reply With Quote
Old 10-09-2006, 07:55 AM   #4
jacobs
jacobs's Avatar
73+ front springs are longer. I'd go to a spring rebuilder and get them rearched and have additionall leaves added. This is usually much cheeper way to go.
jacobs is offline   Reply With Quote
Old 10-12-2006, 05:26 AM   #5
vtblazer
vtblazer's Avatar
Here's a link to a site with frame dimension's.
It should help answer the later model 'fit' question for ya.
http://www.chuckschevytruckpages.com/framespecs.html
