Old 03-26-2016, 12:27 PM   #1
SnS C10
SnS C10's Avatar
Engine frame mounts don't fit 64 c10
Ok everyone I have a 64 c10. I have a swapped in a front crossmember from a 77 c10. I have the original frame mounts from the 77c10. The bolt holes on the crossmember line up, but on the frame rail, there is about an inch gap and the holes are offset from eachother. What is the deal here am I missing something?
SnS C10 is offline   Reply With Quote
Old 03-26-2016, 02:12 PM   #2
jtrichard
Re: Engine frame mounts don't fit 64 c10
Some of the guys have used 1" box tube as spacers and others have cut the brackets to fit there are pics floating around of both
jtrichard is offline   Reply With Quote
Old 03-26-2016, 07:17 PM   #3
chevy2tom
chevy2tom's Avatar
Holy sh#t!, worry about the bubble gum/calk gun job on the engine mounts, Cut that off first!
chevy2tom is offline   Reply With Quote
Old 03-26-2016, 09:18 PM   #4
notsolo
notsolo's Avatar
What engine are you going with. Those mounts look like 1/2 of the clam shell from a newer truck! (Missing the rubber insert, and top ) and Regular SBC mounts from a 64 will work, may need 1/2" to 1" shim on top.
notsolo is offline   Reply With Quote
Old 03-27-2016, 12:26 AM   #5
Captainfab
60-66 Nut
For a better fit, you will need the frame brackets from a '73-'87 C20 or 30. They will fit the frame height much better. Or you could just shorten those to fit. If you do, do that cut all that horrible looking crap off of there and use the correct mounts.
Old 03-27-2016, 12:53 AM   #6
Brad54
Brad54's Avatar
There are two things in life where penetration is of the utmost importance: Welding is the other one.
There are also two things in life where making sure things are clean before getting started is of the utmost importance: welding is, again, the other one.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 03-28-2016, 12:14 AM   #7
andyjust4today
I just went through similar on my 65. After 72 the mounts and perches changed drastically. For a 64 application use pre 67 perches and mounts and make a new hole in the crossmember. In mine the clam shell mounts made the motor sit way too high in the front.
andyjust4today is offline   Reply With Quote
Old 03-28-2016, 09:27 AM   #8
SnS C10
SnS C10's Avatar
yea I know those welds looks terrible. story is, the guy I got the crossmember from had a Pontiac 400 engine in there and he welded those mounts to the perches. First thing I was going to do was get the nasty looking stuff off of there. The pictures I posted are for mock up purposes only. I have the rubber part of the mount already ordered. I will either make a spacer or shorten these down and tig weld if I go that rought
