Old 08-13-2006, 05:25 PM   #1
Longstep70
Junior Member
4WD vs 2WD frame
Is there a difference between the frames on 4WD and 2WD trucks?
How easy is it to convert a 4WD truck to 2WD? Do the 4WD trucks have the same rear end and coil spring suspension and whatnot?
Andy
Longstep70 is offline   Reply With Quote
Old 08-14-2006, 03:03 PM   #2
Longstep70
Junior Member
Re: 4WD vs 2WD frame
Anyone?
I looked in the FAQs and didnt find anything to help
Old 08-14-2006, 03:59 PM   #3
bigbluthng
bigbluthng's Avatar
2wd trucks' frames get wider at the rear as the frame goes over the axle. the 4wd frame is almost straight front to back. converting a 4wd to 2wd is pretty straightforward. you bolt in the 2wd front cossmember and suspension. for the rear you can leave the leafs, just find some that are the correct height you want.
bigbluthng is offline   Reply With Quote
Old 08-14-2006, 05:08 PM   #4
Longstep70
Junior Member
So are the 4x4 rears all leafs?
Old 08-14-2006, 11:46 PM   #5
bigbluthng
bigbluthng's Avatar
yes.
Old 08-15-2006, 02:45 PM   #6
Longstep70
Junior Member
Thanks man, much obliged
