Old 11-04-2005, 01:58 AM   #1
BowTieMan
BowTieMan's Avatar
Adjusting kickdown?
Is there a way to adjust the kick down cable on my 70 350 q-jet with a th350?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 11-04-2005, 03:19 AM   #2
pjmoreland
pjmoreland's Avatar
Re: Adjusting kickdown?
Right in the fat part of the kickdown cable where it is mounted to the bracket on your intake manifold there is a sliding locking mechanism for adjusting the cable tension. Pull the locking mechanism out to allow the barrel that is inside the fat section to slide freely. Push your throttle linkage to wide open throttle (if your engine is cold, you will first have to open your choke manually by pushing on the choke linkage so the choke won't prevent you from opening the throttle all the way). While holding your throttle wide open, push the sliding locking mechanism back into place. Basically the kickdown cable should be pulled all the way at wide open throttle.
pjmoreland is online now   Reply With Quote
Old 11-04-2005, 01:40 PM   #3
70GMCer
70GMCer's Avatar
Hope I'm not stealing the thread here, but, what if the kick down cable, adjusted as you say, does not engage passing gear at WOT? Mine has tension, and pulls all the way out, but still no passing gear. Any ideas?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-04-2005, 08:59 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Steve, are you sure the cable is properly attached inside the tranny?. I bought the wrong cable for my truck and it would never downshift. I finally got a high quality universal cable at the local tranny shop and it kicks like a mofo now!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-05-2005, 08:23 AM   #5
70GMCer
70GMCer's Avatar
Yes Jim...it's attached and hooked up inside. I got this tranny from my son, and he had Jim Jennings Transmissions (In Essex) rebuild it. He (my son) told me he had never hooked it up. So, I'm wondering if somehow the rebuild had by-passed it somehow. I'm not sweating it too much. I have plenty of 350 hp to pull 3rd. Just would be nice to have it working.
1997 GMC Sierra Ext
1965 Mustang
