info needed on a 59 3200 truck
hello
i have 2 3200 apache long bed . so i want to restore one of them and use one as a parts truck . one is a 59 with a small back window and one is a 58 with the panorama back window . there both in the same condition ( grund up restoration ) . wich of the 2 is not so commen . and is there a site wehre i can get god information of history proctions numbers #thanks gregor |
Hollister Road Co.
Re: info needed on a 59 3200 truck
Big window was an option and there are less of them
Try stovebolt.com or send me questions. I have alot of 59-9 data books on options and what would have been era correct. as ar a production number I can't help. |
pics???
![]() ![]() Join Date: Nov 2008
Are they stepsides or Fleetsides?
Personally if they're in more or less identical condition I'd save them both (eventually) unless you just can't - too many parts needed to make good trucks out of them. |
hi there both stepside long bed with 6 hole axel
![]() Join Date: Mar 2009
Generally, the big window trucks are least common and more popular. I imagine that parts are quite hard to find where you are. Do you need to use one truck for parts to fix the other?
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
i was thinking for parts but if i cut get shock absober brackets for the top in front and back . then i would fix both . this sounds funny but this parts a big problem . i cant find any . this is way i board this 2 truck
I know where there is a 56 3600 3/4 ton that is going to be stripped for parts soon, does anyone know if the upper shock mounts are the same as 59 3200 trucks? If so I could check to see if they are any good when I go there in about 2 weeks.
Hollister Road Co.
Same up to 1 ton, 55.2 - 59
