01-11-2009, 09:08 PM | #1 |
3/4 ton axles
what's the common 3/4 ton axles for 4wd's i have one i can't remember the rear end is a 14 bolt and the front end came with it is it a dana 44?
01-11-2009, 09:44 PM | #2 |
Oil trash and damn proud of it
Re: 3/4 ton axles
should be. Dana 60's weren't used until the 73-up 1-ton 4WD. Dana 44's were used in 3/4 tons, and half tons used 44s until sometime between 78 and 81, after which they used ten bolt front axles.
Mark 1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift 1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze 2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons Some of my pics http://s107.photobucket.com/albums/m294/69-350/ Last edited by 69-350; 01-11-2009 at 10:05 PM. |
01-11-2009, 11:12 PM | #3 |
Re: 3/4 ton axles
14 bolts showed up in 73. 67-72 trucks have either Dana 60 or Eaton axle. Dana 44 is all that would be in the front. Disc brakes 71-72, drums the others.
01-12-2009, 01:30 AM | #4 | |
Re: 3/4 ton axles
You sure about the rear though? I thought 69-72 4WDs came with 14 bolt rears, along side the Eatons?
Mark 1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift 1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze 2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons Some of my pics http://s107.photobucket.com/albums/m294/69-350/ |
01-12-2009, 07:08 AM | #5 |
Re: 3/4 ton axles
What year is the truck?The Dana60 front end never came in a K/20 and not until`77 (I believe) in K/30s.GM went to the 10-bolt front end in (I`m guessing)`78?`80?Somewhere around there.Never had a 4wd between `72 and`84,personally.So not real sure.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-12-2009 at 07:10 AM. |
01-12-2009, 08:59 AM | #6 |
Re: 3/4 ton axles
Dana 60s are one ton front ends only, almost everybody, except Dodge, who put them in 3/4 tons equiped with the Cummins. Not sure when they began Dana 60 fronts though, maybe when they started 1 ton 4WDs? Somewhere between 78-81 they phased out 44 fronts, according to what I've read. I'm assuming 78 they started the 10 bolt and mixed and matched trucks until 81 when they stop putting even one 44 in anything.
01-12-2009, 09:04 AM | #7 |
Re: 3/4 ton axles
01-12-2009, 09:05 AM | #8 |
Re: 3/4 ton axles
01-12-2009, 09:11 AM | #9 | |
Re: 3/4 ton axles
01-12-2009, 09:18 AM | #10 |
Re: 3/4 ton axles
01-12-2009, 09:29 AM | #11 | |
Re: 3/4 ton axles
01-12-2009, 09:34 AM | #12 |
Re: 3/4 ton axles
01-12-2009, 11:55 AM | #13 |
Re: 3/4 ton axles
Dodge W200s had Dana60s in the late`80s for sure.I know a guy who ordered a cab`n`chassis one ton`70 4wd.I never went to see it,but believe this guy.I believe they put a D44 in there.The front didn`t have budd wheels.
01-12-2009, 02:35 PM | #14 | |
Re: 3/4 ton axles
So now that's we've totally hijacked the thread, going back to Dova, check what the front is. It's not hard to replace the front axle with something else. Who knows what somebody did. I've come to learn a lot of PO's are lunatics.
01-12-2009, 05:42 PM | #15 |
Re: 3/4 ton axles
From trucks I've seen over the years, 1/2t got a 44 up to 78-ish, 3/4t up to 80, which can depend gears. Pre 73 got Eatons, up to 80 all 3/4 and 1 tons got the 14ff. After that, hit or miss on 3/4 getting a full floater.
GM never put 60s in 3/4t, only 1 tons. That started in 77. They did have 1 tons prior to that, but just got the 44hd with big lockouts. Few and far between. Fords and Dodges put 60s in 3/4t, just about all the 60s that I've had were from a 3/4. Dodge started in the mid 70s, not sure exactly when. Ford did some stupid stuff, a low pinion 60 in 75-77s or something. Then 77.5 started the high pinion. In the 80s, only the 1 tons got the 60s again. Dodge could be either a 3/4 or a 1 ton to get one.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-12-2009, 08:45 PM | #16 |
Re: 3/4 ton axles
When did Dodge get away rom the internal hub?They weren`t Dana60s were they?wasn`t that into the`80s?
This is good discussion.It`s not really a hijack.We`re just borrowing the thread until Dova comes back with what his truck is.
01-12-2009, 11:48 PM | #17 |
Re: 3/4 ton axles
Well, it got moved anyways. Haha. Took me til a few posts ago to realize that! haha. Informative thread anyways. I'm always a nerd for information, even if it's mostly useless to me.
01-13-2009, 12:12 AM | #18 | |
Re: 3/4 ton axles
Fords used the HP60 in '78/79, then they dropped all solid front axles from their lineup from '80-85ish, when the F350's got HP60's back. I think 1991 was when they switched to balljoint knuckles, but i'm not sure.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
01-13-2009, 12:35 AM | #19 | |
Re: 3/4 ton axles
01-13-2009, 08:54 AM | #20 |
Re: 3/4 ton axles
Now it`s a Dana50 in Fords? or something like that,isn`t it?
01-13-2009, 08:59 AM | #21 |
Re: 3/4 ton axles
They came in the picture somewhere. I think in the twin traction beam era.
01-13-2009, 09:22 AM | #22 |
Re: 3/4 ton axles
My BIL`s F350 has one,a solid one.It`s about a`99 I think.
01-13-2009, 02:37 PM | #23 |
Re: 3/4 ton axles
D50 up front? I think they did put them in still. I'd have to research more into it later, but I believe you're right.
01-16-2009, 10:46 AM | #24 |
Re: 3/4 ton axles
01-17-2009, 11:21 PM | #25 |
Re: 3/4 ton axles
not to hi-jack... lol...
but my 68 does have the 44 front... and i thought a 12 bolt in the rear..??? i will take a picture in the daytime and post it up... maybe i have the eaton... i don't think it's a dana.... |
