Rear window install
I need to install the rear window into my 67 C-10. I did a search and know about the rope trick but should I start with the top or bottom? Where should the ends of the strings be at the start of the project? Can one guy pull this off? Thanks
'69 SWB '76 International "Terra" "Hooked on holiday beer" |
Jostrans68
Re: Rear window install
I started at the top I also used a bit of KY mine was a slider and went in easy with 2 people Jack
![]() former 67-72 now with a 96 silverado |
BlahBlahBlah
i can just see me buying some ky for doing this...at the checkout over the loudspeaker: i need a price check on econo size ky jelly...he says its for installing the rear window on his 71 chev truck...snort.
i've had no problem installing a rear slider myself// wrap the rope so the 2ends are at the bottom middle put the bottom in first then slowly pull one side at a time i used dishsoap for lube
More Cowbell....
I also started with the bottom first. I figured...why fight to try and hold it up...let it rest on the lip and go from there. I mixed some dish soap with water in a spray bottle and kept it wet. Slid in with very little force.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I do mine myself.
Use Goop hand soap for lubricant. Much cheaper than KY and less embarrasing. 99 cents a can at Wal-Mart and you need it around the shop anyway. One guy can do it himself. Wrap the string around the groove so the ends meet on the bottom and overlap.
FORD is a 4 letter word.
Just Did mine yesterday. Started at bottom.
Putting the rubber on the window and using a string was a pain in the a$$ & it almost ruined my seal. So, I put the rubber in the truck & worked the window into the rubber using a screw driver. Would have been easier if my old man's window tool wasn't at work. My window was a slider.
'71 406 GMC Short Box Fleetside - Daily Driver '79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com '58 LT1 Chevy Short Box Step Side - Next Project |
Lovin' Life in Miss.!
My daughter held it from the bed of the truck. Started rope from the bottom. I pulled from inside. I used no lube.
The truck... you hear that? No really, you did hear that?!!! |
#9 | |
![]() ![]() Sorry couldn't resist. I used WD40.....installing my window!!! Tim
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) Last edited by Tim240Z; 05-01-2006 at 09:42 PM. |
Jostrans68
watch the wd it breaks down the rubber and ther is nothing worse than a broken down rubber
