Old 04-26-2006, 03:13 PM   #1
oj70chevy
250 V-6 Club
oj70chevy's Avatar
blinker will not work
I installed new LED’s on my 70 short step side. Yesterday but for the life of me the blinker will not work . The parking and brake light work fine just not the blinker. Also the blinker was working before I add the LED’s. any idea on how I could fix this problem?
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 04-26-2006, 03:24 PM   #2
Lemield
Lemield's Avatar
Re: blinker will not work
Did you install an electronic flasher? I don't know about your LED's but my kit from ECE came with an electronic flasher that was required. Just a thought.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 04-26-2006, 03:26 PM   #3
oj70chevy
250 V-6 Club
oj70chevy's Avatar
No I did not. Is that something I could buy at any auto parts? also where would I hook it up to?? Thanks.
Old 04-26-2006, 04:21 PM   #4
Orange '71 GMC
Orange '71 GMC's Avatar
Yup, you can grab it at any parts store.
It will be the same size/PN# as your stock one, just an electronic version.
Also, if after you get that done, it doesn't work still, spin the bulbs 180* in the socket, as LED's are polar sensitive.
Orange '71 GMC
Orange '71 GMC is offline   Reply With Quote
Old 04-26-2006, 04:27 PM   #5
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Cool thanks for the info. Can't wait to get off work to pick one up.
Old 04-26-2006, 07:06 PM   #6
70c10
67-72 Addict!
70c10's Avatar
I used an EL-12 flasher for my LED's.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-26-2006, 09:04 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The old mechanical flashers heat up from the amount of current that passes through... much like that single white X-mas light does. Once it gets to a certian temperature, it opens the circuit untill it is cool enough then it closes the circuit again.... like a circuit breaker.
Since LEDs run off of mili-amps, instead of multible amps, there is a huge reduction in current traveling through the flasher. Therefor, it doesn't get hot enough to open the circuit.
An electric flasher.... is contrilled electronicly.
Old 04-27-2006, 09:20 AM   #8
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Thanks for all the great info guys.
Old 04-30-2006, 10:19 PM   #9
oj70chevy
250 V-6 Club
oj70chevy's Avatar
I did try the electronic flasher and it still does not work . I swaped from the leds to a regular bulb and that works fine. any other ideas?
Old 04-30-2006, 10:23 PM   #10
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
does yours have a extra ground wire? you might have to hook those up. Also check the ground for the taillight harness make sure that one is still getting good contact.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 05-01-2006, 08:36 AM   #11
oj70chevy
250 V-6 Club
oj70chevy's Avatar
there is 3 wires that go from the LEDs to the plug. When you say hook them up, What exactlly what do you mean?
Old 05-01-2006, 07:15 PM   #12
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
mine had wires that ran to the plug and another wire just by itself. The extra wire was a ground wire. I guess yours doesn't have that.
Old 05-01-2006, 09:26 PM   #13
68haywagon
I'm watching you!
Might need some of this!!
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 05-01-2006, 10:54 PM   #14
rkarr
rkarr's Avatar
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
