So Many Ideas, So Little Money
changed rears ot the posi in(71 2WD 1/2ton leaf truck) changed the pinion seal, wondering if the yoke nut is too loose, when I accelerate its normal let off the gas and there is a noise, I can get rid of the noise if while Im braking I give it just a little gas. any ideas?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa Last edited by chevy2racr; 05-31-2003 at 11:23 AM. |
Nothing fits but the oil
My guess is probably, I had a ricer 4wd with the same symptoms and indeed it was the nut too loose.
Land of the free Because of the brave |
anyone wanna second that, thanks man, my neighbor(who is a ford man) brought that thought to myhead. even though he's a ford man he is a badass neighbor! thanks lngbed71 just wanna get a couple agreements before I go and F' it up by crushin the sleeve to much, cause I gotta get it goin so got a vehical again...
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
I think there is prescribed torque for that nut, I didn't want to "crush" the crush sleeve on mine and left it loose only to blow up the a$$ end of the truck. It's almost impossible to "crush" the crush sleeve, that's why it's there.
thanks lngbed71, I called someone and told them the situation and they agreed got under and i see yeah, that was it. driving it that ittl bit must have loosened te pinion up cause it wasn't moving when I tightened it the first time... thanks
Bryce
You are welcome, glad to help out.
Guest
Posts: n/a
This is a thread I asked two days ago. You might want to check this too.
rear driveshaft/ Differential yoke: I have a two piece driveshaft for my 1/2 72 gmc longbed. The nut that attaches the rear yoke on the driveshaft to the differential has come loose and almost fallen off three different times. Its wearing down my gears. I'm about to put a lock washer on it to keep it from comming loose until I can have it looked at. Any ideas why this is happening and what can I do to keep it from doing it again? Thanks for the help.! Class of 69 Senior Member Registered: Mar 2003 Location: Stillwater MN Posts: 322 That nut should be a self locking one! Have it replaced with a new crimped nut...not a nylock nut, a crimped, all steel nut. |
I have changed them in a few trucks and i always get the nut as tight as i can. No problems yet.
hey truck... is that a yenko?
Yea. It a real Yenko. It was ebay a few months back. The picture is as close to owning one as i will ever get.
Forgot the picture.
LoL, nice
