Old 08-06-2008, 01:06 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Flip kit
Whats the best rear flip kit to level a truck out? 72' C/10 2wd lwb coil spring.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-06-2008, 01:12 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Flip kit
If you have a coil spring rear end your gonna need blocks or lowered coils. You can only do a flip kit on a leaf spring truck.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-06-2008, 01:20 AM   #3
thirdstreettito
Resident of Here
Re: Flip kit
Where could I get the best ones? And how many inches of rear drop to make it level?
~Bradley~
Miss having a truck
Old 08-06-2008, 07:18 AM   #4
Re: Flip kit
Blocks aren`t the best way to go.A pair of drop coils is the best.You can choose your drop.To level a truck you`d normally use -2" coils.
Leaf spring flip kits will only drop a truck whatever comes out of placing the axle over the springs...one choice,FYI.
Old 08-06-2008, 08:46 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Re: Flip kit
I have no idea how much its gonna take to drop the rear of your ride.. post some pics and we can guess..
MEMBER #6377
Project "7DEUCE"
Old 08-06-2008, 09:20 AM   #6
steelhorse
steelhorse's Avatar
Re: Flip kit
Measure your truck at the wheel well front and rear and subtract the difference,that is how far you need to lower it to make it level.Usually around 2 inches as mentioned above.
steelhorse is offline   Reply With Quote
Old 08-06-2008, 11:35 AM   #7
thirdstreettito
Resident of Here
Re: Flip kit
Damn, we have no bed or rear axle in... So 2-3" good?
~Bradley~
Miss having a truck
Old 08-06-2008, 11:59 AM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Flip kit
It may take 4-inches to level it out, without lowering the front any at all.
Early Classic Enterprises has everything you would need. So do others who sell parts on this website.
Bear in mind, that if you lower the rear of the truck 4 inches or more, you will need to shorten your panhard rod or use an adjustable track bar (ECE). You will also want to use shock relocators to reposition the shock mountings to enable them to work correctly. If you don't, they will be placed at a more extreme angle and will not give you the dampening/snubbing effects that you want. You can go as low as 6 inches lower than original and still use these same add-on items (track bar/shock relo). I did 2.5 inches of lowering in front and 4 inches in back. I'm running 245-60's in front and 275-60's in back and it has a rake, i.e., it ain't level. Didn't want it level.
If all of your suspension stuff is up-to-snuff and your frame isn't tweaked, then measure from a level floor surface to the bottom side of the wheel opening and subtract what it would take to get it level. That's how much drop you will need.
Member Nr. 2770
Old 08-06-2008, 02:46 PM   #9
corn
Re: Flip kit
Maybe your Uncle could make you a set of top secret drop springs!
Im having a little trouble with all of your questions. You are 15, you dont have a truck but you have owned 3 vehicles & now have 3 others, your grandfather was a multimillionaire & you are always looking for parts to put on a 72 truck (that you dont even own?). I have trouble taking anything you say seriously, can you please fill us in a little? Are all of those vehicles your dads or is it just fun to make up stories for all of us?
corn is offline   Reply With Quote
Old 08-06-2008, 04:27 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
Re: Flip kit
dude please tell me you have a truck? if ya do please post some pics.. I dont get on the board much but I am on vacation so imma on all the time this week so lets see some pics of the mystery machine and I dont mean the one I posted....
MEMBER #6377
Project "7DEUCE"
Old 08-06-2008, 11:21 PM   #11
Re: Flip kit
He has shown pictures of his brother`s truck in a prior post outside of his house along with the Jetta.The rest I have no clue.
Old 08-07-2008, 08:32 AM   #12
70cstjr
70cstjr's Avatar
Re: Flip kit
should i even say anything?....nah...you guys have said enough
PROJECT CIRCUIT RIDER
70cstjr is offline   Reply With Quote
Old 08-07-2008, 09:32 AM   #13
thirdstreettito
Resident of Here
Re: Flip kit
All the vehicles are/were my dads. The C/10 is my brothers, I do work on it everyday, he doesnt even live in the same state now. The Rabbit we are selling so it is no longer mine. The Jetta I drive more than anyone. And the Dodge, Camaro, and K10 were my dads, but my favorites of his.
My life is a bit complicated to people online, easier to tell the story in real life, that way I can use expressions and answer questions quicker.
http://67-72chevytrucks.com/vboard/s...d.php?t=291757
Not easy to tell how it sits, I dont even remember...
It is still on cinder blocks. They are more steady in the mud than the jack stands.
~Bradley~
Miss having a truck
