01-03-2018, 08:08 PM | #1 |
Leaf spring line question
Took the front springs out of my '53 AD truck. Took the leaves apart. Going to grind off the rust and paint them. Should I use the vinyl spring liner between every leaf or just the longer ones? -or- Skip the liner and put white lithium grease between the leaves after painting.
01-03-2018, 10:02 PM | #2 |
Re: Leaf spring line question
Sandblast them and paint them all together. No reason to take them apart...
01-04-2018, 10:42 AM | #3 |
take them apart, grind or blast them, paint & re assemble. that way you don't have grit between the leaves. I installed the Teflon liner many years ago & it still works well. it was worth it.
01-04-2018, 11:11 AM | #4 | |
Update: I found teflon buttons at ATS Suspension products. They also had Kwik Clips for 1 3/4" springs. Update ll: After speaking with Nostalgia Sid who is making me an adjustable drag link I'm going with the liner between every leaf. Last edited by xaircav; 01-06-2018 at 01:11 PM. |
01-05-2018, 12:22 AM | #5 |
Liner is great. The longer the leaf, the more effective it is. Doesn't do much on the top leaves but what does it hurt to install it anyway?
