Old 01-07-2014, 06:38 PM   #1
OKGMC4
OKGMC4's Avatar
Drop coil interchangeability? What fits?
My 56 has been done for a year now and I'm bored so I am starting a 69 I got for free. My approach is somewhat strange on the front. I am using 73-87 control arms and drop spindles on the 69 k member, and I am adapting a dodge dakota rack and pinion to the frame for steering.
The question is this...why aren't the drop springs on 73-87 trucks the same part number as 69-72? The spring pockets all look the same and the K members are nearly identical. Not sure which ones to order?
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 01-07-2014, 06:58 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drop coil interchangeability? What fits?
67-72 and 73-87 front springs will interchange.
Keith
Convert to disc brakes.
Old 01-07-2014, 07:02 PM   #3
OKGMC4
OKGMC4's Avatar
Thanks. That's what I suspected. Just strange that all aftermarket springs say either 67-72 or 73-87 but not both.
Old 01-07-2014, 07:03 PM   #4
lolife99
lolife99's Avatar
Where are you looking?
Keith
Old 01-07-2014, 08:40 PM   #5
OKGMC4
OKGMC4's Avatar
JEGS, Summit, ECE, LMC. The part numbers differ. I used the Federal Mogul website and they are different there too. I don't doubt they fit but a slight change in spring rate or free height makes it a different part number. A long time ago I put third gen firebird springs in a second gen TA to get a 1.5 drop in the front. A ton of GM stuff will change out if a person only knows where to look.
