70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Big Block Question
Did the 70 big block trucks come with the 396 or 402? I thought 67/70 were 396's and 71/72 were 402's?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Big Block Question
I think a 70 was a 402 also. Just the 68's and 69's were 396's. Not 100% positive.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Florida Edition
![]() ![]() Join Date: Oct 2010
In 70 they went to a 402 but listed them as 396 or 400. My big block 70 GMC has the original engine and it is a 402.
You can find lots of threads in here about this but the bottom line is that nobody really knows why they didn't badge them as 402's or list them on the SPID as such. I'm glad I have one...
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Thanks for the ionfo. I'm looking at buying a 70 and the owner is advertising it as a 402 and I wanted to clarify as I don't want a transplanted engine .
![]() Join Date: Sep 2001
If the engine is original it should be a 402 with a stamp on the block in front of the passenger side cylinder head like T****TBG (TH-400), or T****TBH (Manual Trans). The stars are for the assembly date. Good Luck!!
Florida Edition
My stock intake casting number is 3955287, 70-71 402. You should be able to see this pretty easily.
If you can get the block casting number off of the top back driver side of the block you can go to this link and decode it... http://www.nastyz28.com/bbcmenu.php The 402 is a good engine...there is a lot you can do with it. Good Luck.
![]() Join Date: Nov 2007
I suppose it has something to do with branding. Since the 1st big block SS chevelles came out it had been "SS396" they had marketed and turned into a brand. Probably not worth it to GM for all the explanation for 6 cubic inches when it is essentially the same powerplant.
However if you got a big block malibu it was called a malibu 400, probably to separate it from the SS brand.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
Roadtrip!
![]() Join Date: Feb 2003
I think this is correct.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#9 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Or the protec-to-plate.
Moderator
...or the protecto plate, lol
