![]() Join Date: Aug 2013
1972 C10 Cab and Fender swap question
Hey guys - I am tired of the way my 72 C10 front end looks. The passenger fenders don't line up all and door is just not right. In addition to that, cab has major rust and repair would not be easy. So, sorry if this has been covered a ton but I found a 1971 C10 LWB in town that I want to buy and swap the cab and entire front clip on. Can I remove some bolts and get a front end loader to lift off the cab and entire front end in one piece? Has anyone done this?
Neil............... ![]() 1972 C10 SWB - Shop Truck in the Works 5.3 LS / Full Air Ride / Rear Notch 20" American Racing Daytonas IG - neilioustx - pictures of build/progress Born and Raised in the Promised Land.... TEXAS Y'ALL!! |
the boat guy
Re: 1972 C10 Cab and Fender swap question
Bolts and wires the front clip will slide right off
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
When swapping the cab, can the current vin, registration and plates for the old cab still be used? Thanks
#4 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Agreeing with above, pull the clip off first and then the cab. As for cab, either save the vin off the old cab for certain purposes or make sure the 71 has a title, depending on the states rules you may have to keep the old vin so it matches the frame.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
Fellas - thanks a ton for the advice. Pulling the front clip first is definitely the way to go. I will let y'all know if I can make a deal. Thanks, Neil
![]() Join Date: Sep 2013
I have moved a few cabs around and this is what works best for me. Get a large engine hoist and put the boom on the cab roof as close as you can get it to the windshield. Plywood will keep the roof from denting.
hope this helps
Real trucks have a clutch. Please inform automakers. ![]() 1972 GMC, K25, 383 stroker, SM465, NP205, Eaton HO-72 |
