12-27-2009, 02:05 AM | #1 |
engine hoist
I've never used an engine hoist before and i wanted to know where to bolt it up to my 350 engine. i have the attachment with the horizontal tilt design if you know what that means.
Thanks! |
12-27-2009, 02:11 AM | #2 |
Re: engine hoist
Are you taking the engine out, or putting it back in? i suspect you're taking out, but i thought i'd ask to make sure----it will affect my answer.
12-27-2009, 02:14 AM | #3 |
Re: engine hoist
im taking it out sorry
12-27-2009, 02:15 AM | #4 |
Between Trucks...
Re: engine hoist
I bolt a couple pieces of chain to the heads.
Beat it to fit, Paint it to match... |
12-27-2009, 02:16 AM | #5 |
Re: engine hoist
but where. does it have an affect on your engine?
12-27-2009, 02:20 AM | #6 |
Re: engine hoist
this is what im using
12-27-2009, 02:24 AM | #7 |
Between Trucks...
Re: engine hoist
I bolt to the holes in the head for accessories.
12-27-2009, 03:35 AM | #8 |
70 Chevrolet=Obsession
Re: engine hoist
You can also buy a lift plate that bolts in place of the carb on the intake manifold. They don't cost much.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
12-27-2009, 07:58 AM | #9 |
ENGINE BUILDER
Re: engine hoist
Use the engine tilter. I finally bought one after all these years and it is the only way to go!
JIM ZAG |
12-27-2009, 09:21 AM | #10 |
The Older Generation
Re: engine hoist
I have always used the intake manifold bolts without any problem. Just take one out on each end and use longer bolts with washers. I would like to have one of the carb plates that unclewatts mentioned and I think it would work good with the adjuster. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-27-2009 at 09:24 AM. |
12-27-2009, 09:45 AM | #11 |
Re: engine hoist
i used a bolt hole for the exhuast manfiold casue they wheren't on teh truck
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-27-2009, 09:53 AM | #12 |
Re: engine hoist
I just have a length of chain with hooks at each end that I hook through the factory lift tabs which are placed diagonally on longer intake bolts, i.e. one tab on right front, one tab on left rear. I always hook the crane hook a link towards the back of the lifting chain so it lifts with a tilt to the back.
Just as important in pulling or installing an engine is where you are doing it. You need level concrete and enough room to maneuver the engine crane. You are going to have a lot of weight up in the air so be careful. Stay out from underneath it and a helper is always good. As soon as you clear the vehicle, lower it down as it is much safer to move with a lower center of gravity. Do you have an engine stand to bolt it on once removed? I suggest a 4 wheel one as opposed to a 3 wheel stand which is very tippy. Good luck and take it slow and easy.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
12-27-2009, 02:04 PM | #13 |
Re: engine hoist
here was my setup....hope the pictures help.
69 C10 LWB GM 350 crate motor, 3.73 rearend Last edited by rick0312; 12-27-2009 at 02:05 PM. |
12-27-2009, 02:11 PM | #14 |
Re: engine hoist
Which ever way you hook it up make sure that the bolts pull the tab or chain down against the block, heads or manifold. I've seen the sad results of a couple of engine lifting operations where the guy used long bolts and had way too much stress on the bolt causing it to snap. It's also a lot better to pull against the tension or length of the bolt rather then the shear of the bolt.
12-27-2009, 05:15 PM | #15 |
Re: engine hoist
For that type of attachment you can bolt the tabs to the heads like rick has shown or bolt them at the 4 corners of the intake. The tilt option is a great advantage.
12-27-2009, 05:23 PM | #16 |
Re: engine hoist
i just use a length of chain that i've been using for 45years and my dad used for i dont know how long// never hed a problem bolting into exhaust area on V8's of all makes and sizes
