Which new battery to put in truck
I am putting my truck back together and am close to firing up the motor. I need a battery and was wondering what size some of you are using. It seems like the application charts are all over the board. Some are suggesting a side post bettery, some top post, and the group or sizes all vary.
I've got a 71 with a 350 automatic, no air (although I want to put aftermarket air in at some point), I've got a late model internally regulated alternator if that matters. Any suggestions? Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Junior Member
Re: Which new battery to put in truck
75DT should work. It is a dual terminal, side and top. Now brand just depends on which one you like.
I have had good luck with Interstate, my brother swears by Diehard. I am sure others will chime in with more info.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Are you running side or top terminals?
![]() Join Date: Dec 2003
I run a side terminal interstate, the biggest one they offer
https://www.ebay.com/itm/295742064443 |
Which terminal is closest to the fender, positive or negative?
if i remember right it's the neg...
Just last week the battery in my truck went Tango Uniform ... replaced it with a red-top Optima, 75/25, with top and side posts/connection. 3 year warranty as I recall ... $150 at AutoZone.
Barry
Barry L. Van Hook '69 Chevy Frankentruck |
i usually go for sears batterys have had great luck with them over the years. have also had pretty good luck with the few batteries i've gotten at walmart too believe it or not
had terrible luck with optima batteries wayyyy overprice IMO
Group 24 or 24-F fit well, with top post, 650 or so cranking amps. The difference with 24 and 24-F are the terminals are reversed. Positive and negative are swapped. Whatever you like better for your wiring. (F stands for Ford, by the way, of course they are backwards!) I run a 24-F. Personally I don't like side terminals because there is one more for a POSSIBILITY (Not definately!) of a leak developing. Plus, the small screws can strip if you're not careful.
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod ![]() 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. |
#10 | |
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 02-04-2011 at 03:18 PM. |
#11 | |
Had good luck with Delco and Interstate. |
Duralast Gold from Autozone! biggest one they have in a top post! never had any luck with side posts bc they come loose and then your truck wont start! my jimmy has a Duralast Gold in it and a short so it runs down all the time bc it sets while im at school just throw a charger on it and its good to go! 8 year warrenty (3 year free replacement, 5 year pro-rate after that)
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
#13 | |
I like to side terminals as it's less likely one of my buddies (none of which are mechanically inclined) will hit a terminal with a tool, ring or beer can. ![]() |
#14 |
Newbee
X2 on the Duralast gold. I have 5 vehicles with them. I am averaging 4 years on the lifespan. When they die, I take them back and get new ones for about 60.00, with the warranty.
4 years on a battery in Phoenix is almost unheard of. |
#15 |
oldschoolblazer@yahoo.com
Deka Batteries Made in USA
I used them at work and have had Great Luck Group 78DT (Dual Terminal) You could always attach accessories to the spare terminal. Posted via Mobile Device |
#16 |
Deka is a good battery too. I've used them in the past and had great luck. Usually last 4-5 years
#17 |
Decide if you want top or side terminals.
Decide where you want the + and - terminals. Measure your battery box. Buy the biggest (most CCA) battery you can find that fits in the box with the desired terminal setup. Never beat on the terminals. Last edited by 72lb4x4; 02-04-2011 at 07:24 PM. |
#18 |
![]() Join Date: Mar 2010
I have an Odyssey PC925 Dry Cell that I bought from Summit. In my estimation, the best battery you can buy and the company will back you 100%, I can vouch for that, I will give you the vice-presidents name if you want it. Couple that battery with there battery maintainer and you are good for years.
#19 |
"the other guy"
i use the bottom line ones from walmart, run them in everything i own.never had one go bad.....only replaced after 6 years just for good measures. only had luck with the cheapest ones, STAY AWAY FROM THE "-N-EVERSTART MAXX"
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
#20 | |
Sierra Grande Club
But I'm using an Odyssey PC1700 MJT battery in my Land Cruiser and it's been trouble free since October 06. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#21 |
![]() Join Date: Oct 2010
Huh...
I have an Optima going on 8 years. Get's a little tired, throw the charger on it on 2amp for 4-5 hours, ready to go. Just don't let it sit and it's fine. Have a Duralast Gold, it's about 3, surprised it's lasted that long too. |
#22 |
Everybody's different, I guess ... I've been using Optima for years without issues. And this is in the Phoenix heat.
#23 |
#24 |
its all about the +6 inches
I put a set of used interstate side posts in my longhorn back in 04 or 05... I think they are from 03 maybe? Still kickin hard. I've let it sit for 4 months or so and it cranks fine. These are older ones, pre-green top. They are black top if memory serves. The quality seems to have dropped since they went green top. We get a lot more call backs than we used to.
The side posts are better in many ways, and were implimented in 71. The main reason GM did this was to move the terminals away from where the corrosive gasses vent out the top. This is why it is uncommon to get corroded terminals on side posts. The crappy part is, if you do get corrosion, it is all but impossible to clean. |
#25 |
Old member
These batteries are hard to beat. The odyssey 925's is what I use in the dragster golf cart and I want change a thing when they quite. I'll buy 6 more and keep on going!
You can mount them in any way shape or form and it want hurt them. They can be discharged all the way down and charge right back up. They have a 2 year shelf life. ![]() http://www.odysseybatteries.com/batteries.htm
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
